![]() | Home > Maintenance & Mods (L322) > Blown turbo |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
yours [3.6] ?
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Thanks stan , driving hard about 30 mph , loss of power and plumes of white smoke, drove about 1 mile home. 3.6 223000 kilometres on the clock 2015 4.4 AB
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
White smoke indicates coolant. It could be through the EGR cooler. ______________________________
Thanks for the response but there is oil coming out of the nearside exhaust, its at indies now and he will be looking in the morning , iid tool had a few engine fault , one being manifild pressure low so i think a seal has gone and allowing oil into turbo. Have a price of 400 to get turbo reconditioned. 2015 4.4 AB
Euros? Oil seal sounds right. ______________________________
Hi , yes euros and they use quality parts so will get both done. Turbo shop has offered to test both but i think i will get both done either way.
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
Engine drop is easiest and quickest I believe. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
Subframe off and support the engine from the top |
Mechanic just called , he took.engine out and left hand turbos.main shaft has broken in two-pieces. Front part still in turbo housing and rear part had fallen into exhaust. 2015 4.4 AB
That's interesting. I have heard of it happening, but not on a RRV. It's a lot better for bits to flow into the exhaust than into the pots. I wonder why this happened. So i assume you are still rebuilding the turbos, as you would be replacing the impellers, surely. ______________________________
Hi, yes , both turbos being rebuilt tomorrow, car has 233000 kilometres on it so maybe wear and tear, car is remapped but i dont drive it that hard , i have a new oil feed pipe to be fitted as well. Typical , i was to view a 4.4 ab in clonmel yesterday. Last car i had was a 320 cls and i had for 6 years without a bulb blowning and the day i collected the FF it broke down costing over a grand to repair. Such is life 2015 4.4 AB
Just an update , turbos in for rebuild and second ( non broken ) turbo had a lot of carbon build up and oil seal / ring was weeping so rebuild was in order.
Was the carbon build up on the hot or cold side of the turbo? ______________________________
I will ask, this was what the turbo man told me. 2015 4.4 AB
