Home > Maintenance & Mods (L322) > Interior Heater Troubles
Webbie
Your thoughts and experience would be appreciated:
Car interior is not getting up to and maintaining its temperature. On "auto" setting the fan does not seem to be blowing as it did previously, but it blow when the manual settings for footwell, mid level etc. are used. Although the warmth of the air coming through seems cooler than before. Defrost mode seems to work normally.
The car has just come back from an inspection 1 service and new primary drive belt, pulleys and tensioner being fitted. All was perfect with the climate control before the garage visit.
The radiator has been removed/refitted and all of the filters have been changed including the cabin/pollen filter.
The car was half a litre short of coolant after 700 miles and five days. The dealer took the car back, topped up the coolant and pressure tested the system agin. Saying the computer does not show any fault with the blower.
I am wondering if there is likely to be an airlock blocking the heater matrix, or a pipe dislodged in the process of changing the cabin filter.
Thanks for reading my overly long post.
Post #426205 4th Feb 2017 8:52am
Webbie
Additional info: fans workday normally from cold start to this morning, blowing warm air. When the car reached normal oporating temp on the gage, the fan stopped blowing and air went cool. Side windows started to mist up.
Post #426209 4th Feb 2017 9:53am
Please edit thread title from "hearer" to "heater" Thumbs Up
Does sound like you have an airlock somewhere, can be tricky to bleed all the air out. Also possible faulty/intermittent FSR ?
Changing pollen filter unlikely to dislodge any pipes. .
Post #426235 4th Feb 2017 1:42pm
Webbie
Thanks Jo 90. Heading amended. What is the FSR?
Post #426330 4th Feb 2017 11:50pm
Final Stage (Blower) Resistor
http://metricrat.co.uk/tag/fsr/ .
Post #426335 5th Feb 2017 12:50am
