![]() | Home > Maintenance & Mods (L322) > Rear wiper washer squirt question |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
Not sure if it helps but when I press mine, the initial wide (ish) jet pours down the window and is swiped across by the arm, what I have noticed is any extra presses don't do much as the arm gets it before it has chance to travel down the window, let me know if you want me to picture / video anything...jeff |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
The cap that sits over the nut holding on the wiper arm probably isn't located properly, or in my case it's damaged.
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 ![]() ![]() ![]() |
So can you adjust the spray pattern on the rear wash? Dave
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
Thanks for the feedback. I think I might be missing the nozzle cap that constricts / directs the spray. When I trigger the wash it looks like a cup full of water has just been dumped from the wiper arm.
I'm not sure Dave, I can't even get the water to come out my nozzles, it's just spilling down the window, which for me in an improvement to dripping onto the parcel shelf since I changed the seal........ |
If you're missing the cap completely the it's probably just spraying water through the shaft, out the tip and against the bottom of the spoiler, then dripping down onto the window.
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Same thing happened to me. The arm must be pushed onto the shaft or the water leaks from the base of the arm. I have mine a good bash with a rubber mallet and it was fine. |
I'll check my folding cap as I replaced the wiper arm as well as the motor at the same time. I probably did not push it down hard enough!
Be careful giving it a smack of a mallet, if it's not located properly when you smack it it will either damage the cap or the nipple on the end of the shaft which is what I think happened to mine. |
Checked it again and it comes out from the flap and the nozzles so the cap needs to be sat better. I will need to take of the spoiler to do it properly. Thanks for the advice. Tom
I had another look at mine today, same problem, just coming out under the cap and piddling down the window.
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
For my centime's worth, I’m pretty sure that when I did my wiper motor leak repair some while back, there was a small rubber grommet between the motor output shaft and the wiper arm cap, as in the 2nd photo in hamlet’s post, only mine was rubber rather than the metal (?) one shown in the photo. (I know ‘cos it fell out and I spent ages on the floor looking for it! Happily I found it in the end.)
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
Hi.
I was originally going to do something like that but since the cap was also damaged on mine and I couldn't seem to get a good seal on it I just gave up and drilled through the cap and extended the pipe the whole way out along the wiper arm.
