Home > Technical (L322) > Spoke too soon..
alistairh
Spoke too soon..
Thought I had nailed it. It appears not so lol..for some reason it won't hold revs under 1000rpm. Over 1000 it sits beautifully.. I had a slight success spraying the throttle body with carb cleaner and I'm wondering if I should try again? I have new spark plugs to fit, all filters are changed and fluids and cars not giving me any engine faults apart from an electric thermostat one..
For what it's worth she pulls like a train and is fine apart from this, I have bad OCD and won't rest until I've solved this Laughing
Post #426746 7th Feb 2017 7:46pm
Dolphinboy
Dirty MAFF?
At the end where it goes to 1400 rpm, Is that the automatic "choke" function coming on which it does when the engine is cold or is it you giving some gas?
Post #426747 7th Feb 2017 7:52pm
jonnyboy54321
Looks like an air/vacuum leak with the associated overcompensation.
Get some brake cleaner in a sprayer and as it runs spray all around the engine bay/where you have been busy with other things. Be careful as it is flammable!
When the revs pick up you have narrowed down the area you have a leak. If it is one....
Could you have knocked a vac pipe when doing the cdc (if theres any in that locale?) ? 2007 Vogue TDV8 with 255/55/20's fitted
Post #426748 7th Feb 2017 7:55pm
alistairh
It's me giving it gas.. it's perfect over 1000rpm between 800 and 1000rpm is iffy.. mag looks new but could be dodgy I'm thinking
Post #426749 7th Feb 2017 7:56pm
jonnyboy54321
Explain electric thermostat fault a bit more?
If you have a sensor giving ECU a bad reading then it could be trying to compensate for that.
Seen that with a dodgy oil temp sensor on a tdv8 - idled like crap. 2007 Vogue TDV8 with 255/55/20's fitted
Post #426751 7th Feb 2017 7:59pm
alistairh
Johnny.. I've had this issue before I started working on the car buddy.. will try your method when it stops raining Laughing
Post #426752 7th Feb 2017 8:00pm
alistairh
This one
Post #426756 7th Feb 2017 8:04pm
Dolphinboy
Check your air filter is correctly attached to the pipe as that can cause rough idling?
Post #426757 7th Feb 2017 8:06pm
jonnyboy54321
Ah, just caught up with previous thread. 2007 Vogue TDV8 with 255/55/20's fitted
Post #426759 7th Feb 2017 8:10pm
alistairh
Will double check all connections.. I did remove air box to remove headlight a while back.. had a lot of trouble attaching it at the bottom where the external air intake pipe meets the box.. could that cause it??
Post #426761 7th Feb 2017 8:18pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
+1, that's where my money would be.
Post #426771 7th Feb 2017 8:43pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Mine was fixed with a replacement MAF, but i would see if anyone is local and swap over with a other car first to test.
anything below 1k RPM is would hunt above this it was perfectly fine.
also would get tiny amount hesitation when engine was cold and pulling out.
its a 2003 4.4 V8 just had updated speedo dials.
of course there are other things aswell. so dont just take my word on this.. PVC valve also caused me similar issues. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #426873 8th Feb 2017 2:07pm
alistairh
Looks very much the same until mine gets to 1000rpm then she's perfect. I'm getting it smoke tested for free at the weeekend and if that doesn't give me any resolve I think the maf will be changed.. Pcv systems been overhauled so I can at least rule that out.. mine occasionally dims as well
Post #426961 8th Feb 2017 9:49pm
