![]() | Home > Maintenance & Mods (L322) > Drivers window stuck down at 11pm!!! |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Not having much luck, no one appears to answer phone at 2 dealers! Emailed Furness via Ebay shop. |
Rang my local indy and asked who they use for genuine parts, gave me a No.
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
As you have a 2007, this may be nonsense, but... with the switch disconnected, if you lock the car and hold the key in the locking position, do your windows/sunroof close? Maybe open another window and see if that one works. That would eliminate the switch. |
Spock, don't think it did that before when everything was working. Tried it to see if it put window up but it didn't after fault developed. New switch has arrived but not going have time till Friday fit it👍 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
I think you will find it has to pass through the switchpack to raise the window no matter how you trigger it... The IID will trigger it the same way the global close works which is via the BECM but you have to have a switchpack in place for it to work... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Its fixed |
