![]() | Home > Off Topic > Vacuum Cleaner/Dust Extraction |
daveenty Member Since: 30 Mar 2016 Location: North West Posts: 34 ![]() ![]() |
I've posted this elsewhere but know that there are some clued up people here, so though I'd throw it out to see if anyone can help.
I think that, having looked at several (all expensive) ways to slow the motor down, this is going to be the logical solution.
If you're trying to regulate the speed of a motor then be careful using light dimmers. You need something which can cope with inductive loads, whereas lights are mostly resistive loads.
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
It's possible using a triac or thyristor dimming circuit with a suitable optocoupler for isolation. But if all of this is gibberish to you I'd recommend the bypass pipe route that others have suggested. |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Most vacuum cleaners have that sort of arrangement as standard now with a bleed-off valve. 2007 Vogue TDV8 with 255/55/20's fitted |
Thanks for the responses guys, much appreciated.
Thinking about it I had a similar situation a few years ago with a high end but under-spaced (!!) fountain installation whereby the pump needed to get the head of water flowed too much water and it splashed everywhere.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8773 ![]() ![]() ![]() |
all you need is a hole in the bit of vac pipe going to your cab which you can open or close as needed, a lot of hoovers have this on the handle as standard.
