![]() | Home > Maintenance & Mods (L322) > Windscreen Replacement |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
If they are bigger than 10 mm diameter in total then they can't repair the screen, it's a replacement..... So if they are anything more than a spec it'll be replacement |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I'll take some pics and see what you think. I may also possibly have some dead zones... |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Re the wind noise I'm getting, I'd appreciate if it someone could compare the top seal of their 2003-2004 L322 with mine andlet me know if mine looks right. I'm booked in for a fix on Saturday afternoon).
Grateful for an answer to this before I go to the windscreen place, i.e., does the rain-sensing work when the Rangie is not moving? I see that the wipers change from high speed to low when one stops, and from low speed to intermittent when stopped.
Rain sensing should work when stationary, if nothing else you should 1 sweep when you turn them on.... mine did have a little fit and went constantly to start with, but I think that was condensation cos it started to work properly after 3 minutes of 'Program' defrost. Also that top rubber don't look too cleaver, they didn't clean the old glue off the frame very well.... to fix that properly it's screen out |
I'll give it a try - but it's 8pm and 35 deg C so the screen will dry before i get very far! I've just come in and I'm wet with sweat after watering the garden. I can't see my missus hanging out of sunroof with a watering can. Knowing my luck, the Highway Patrol would go past and grab me. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
If the misses isn't game can't you borrow a child? most 10 year olds would jump at the chance to do something silly like that.. and don't they have either quirt roads or empty car parks down under? |
I don't know any children.
This State really has quite high fines for traffic offences and they hate speeding but they aren't as hot on speeding as in Victoria with their hidden speed cameras and a leeway of 2-3km/h over the speed limit. Speed cameras here have to have warning signs before them. Fixed cameras have 3 warning signs about 50-100 metres apart.
The rain-sensing seems to have resolved itself.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3558 ![]() ![]() ![]() |
Anybody know if pitting can be successfully polished out of a windscreen?
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 ![]() ![]() ![]() |
Interesting on the pictures of the top seal, I have recently found drips down the front of my center console and 2 streaks on the inside of the windscreen, managed to trace it to where the windscreen meets the body at the top, Ive noticed quite a bit of wind noise too at motorway speeds (60-70 mph) had a look at my seal and it isn't as bad as yours P38arover but has certainly shrunk back a bit |
