![]() | Home > General > 2010-12 MY buying advice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35713 ![]() ![]() |
theres one on topix i believe..... ... - .- -.
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
That's pretty helpful, thanks. I read that the Westminster was an edition limited to 300 vehicles worldwide but elsewhere I read it was the new name for the base model in some markets. Is that correct?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1409 ![]() ![]() ![]() |
In the UK the WM was a run-out model for the 322, essentially a Vogue with ventilated seats, 20" wheels, dual view screen, Harmon Kardon system and various trim items. The brakes are of the Brembo type but are badged 'Range Rover'. Only Range Rovers since 1988 |
Cheers, CS |
According to the 2011 brochure all models have adaptive dynamics. Only Range Rovers since 1988 |
In 2012 it was only standard on the Autobiography. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
my 2012 westie has 'adaptive dynamics' so i'm sure all 2012 and possibly 2011 FF's have it.. ... - .- -.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
It's in the 2011 Owners manual. Not mentioned as optional so I believe std on all 2011s. I don't have a 2012 manual to check, may have been charged to option. Also varies by country.... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
Mine has it. There are electrical connections on the top of the shockers if you open the bonnet..... you can't see the big nut etc like you can normally..... 2011 Range Rover Vogue SE 4.4 TDV8
Test drove a '12 model yesterday and realised that the speedo and rev counter have switched positions on the digital display. I'm used to them being the other way around (rev counter on the right, speedo on the left) as in my '08 car. Is there a setting that allows you to swap them around? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Don't believe so....not much you can do with the display to be honest....LR should have utilised it a bit more as far as I'm concerned..... can't even get sat nav directional arrows on it..... 2011 Range Rover Vogue SE 4.4 TDV8
no you cant change the positions but you can change the speedo from mph to kph very easily which is handy for us brits that take the FF abroad.. ... - .- -.
I test drove an 11MY Autobiography yesterday and it had everything except adaptive cruise control. I thought it was standard on the Autobiography so I was surprised that it was not fitted. At least, I assume it was not fitted because the two additional gap increase/decrease buttons were missing on the steering wheel.
The indie is wrong, the buttons allow you to increase or decrease the gap that is leaves to the car in front. Looks like it's not fitted then.
