Home > Technical (L322) > Air Suspenion Issue
Page 2 of 3 <123>
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Paul,
I think you have a different pump to me -It been some time and i've been to bed since I did mine but I'm sure that I first connected the output of the pump to the intake side (think there are some silencers on mine that I got mixed up with) and had the static issue.
I know you will have checked many times but just to be sure Smile Just check that the output of the pump is connected to the correct 'out' pipe. If the pump is producing pressure/air and there are no leaks in the system it should not be static pressure.
PS the reason my pump needed a new seal was that I had a small hole in the blue pipe from the pump to the reservoir - The pump was running all the time and became worn out. I was getting a slow lift warning on the dash. Perhaps if you have a bigger hole the system might not hold pressure....
Good luck,
Simon
Post #427412 12th Feb 2017 12:15pm
alistairh
Just a thought but what diagnostic are you using? Can you read the air resovoir pressure? If you can post it up as that should give us a better idea of what's going on..if it's really low or non existent then it's a good chance it's pump related, there's also a pressure sensor in the tank which can go as well.. Thumbs Up
Post #427413 12th Feb 2017 12:25pm
Paul1234002
England 2006 Range Rover Vogue 4.4 V8 Barolo Black
Simon,
If the pipe had been put in the wrong way would i still get air coming out of the pipe that connects to the car??
Sorry if i am being a bit thick.
Alistarh,
Thankyou for your reply,
I checked the chamber and there was no scoring / damage.
My first thoughts were the same as you (New Pump) but the pump was fine before i serviced it so other than what Simon has suggested ,i cannot see why anything wrong with the pump.
The reason for the service was due to when it was cold /Freezing the EAS would come on, I would reset it and all was good until the next frost.
Post #427414 12th Feb 2017 12:28pm
Paul1234002
Alistarh,
I am using RSW Solutions software. Would this tell me the answer. I wouldn't mind but i ordered last Thursday a snap on solos pro.
Post #427415 12th Feb 2017 12:30pm
miggit
Whistle As I have stated many times, once the compressor stops pumping it inevitably ends up in a new compressor.... if your going to fit new piston rings the time to do it is before the compressor plays up..... normally once the compressor gets weak the cylinder is scored, and as it's a chemical liner, there is nothing that can be done other than replacement Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #427416 12th Feb 2017 12:30pm
miggit
Whistle EAS inactive message can often be caused by low battery voltage....
"The reason for the service was due to when it was cold /Freezing the EAS would come on, I would reset it and all was good until the next frost."
I'd possibly check the battery voltage.... if it's below 12 volts then I would suspect that... towards the end of my battery I regularly got EAS inactive on the screen of Doom Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #427417 12th Feb 2017 12:35pm
alistairh
Paul1234 . not sure about your diagnostic but most can read resovoir pressure.. the scorings not noticeable in the chamber..
Post #427418 12th Feb 2017 12:36pm
Paul1234002
Alistar, There was no scoring at all.
Maybe i should just buy a new pump and see?
Post #427419 12th Feb 2017 12:46pm
miggit
An ffrr (L322) is like a baby... it will often spit out its' dummy for no reason, and when there is something wrong, it doesn't always have the correct vocabulary to convey the problem.....
There is no screen of Doom message for flat battery... so it usually comes up with HDC inactive or in extreme cases of low voltage EAS inactive, when all the time the battery is sitting below 11.4 volts.
Why 11.4? my well used battery functioned happily at 11.5 for a year Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #427421 12th Feb 2017 12:53pm
RP123
Paul,
Sorry if I confused you ( I confuse myself often) - You have a different set up to mine - so if the out is going out to the resevoir your ok.
On mine there are two holes / pipes in the end plate of the dryer, i'd got these mixed up.... Embarassed
When you clear the codes do they come back again before you try the pump again or is it after the pump had run?
I would have thought it would take 30 secs or more befor the system thought it wasn't being filled.
You could also try a battery disconect - but I think it's a hard fault you are trying to clear -What i'm trying to say is - is your reader/ clearing the hard fault? if not you may just need it to be reset...
Simon
Post #427425 12th Feb 2017 1:10pm
miggit
Buddy if your EAS is working when you've reset the system, with out fault, then it's not the EAS system that's causing the message in the first place... plugging in your box of tricks doesn't magically repair worn out components.. Your obviously new to Range Rovers, and haven't gotten used to their quirks... the biggest problem is the all singing and dancing computer is actually stupid, and lacks the messages to convey the real problem, so it has a panic throws up no end of faults, the new owner spends thousands of pounds on new parts only to discover that there is still a problem.. eventually you will get to the route cause..
I owned a ffr for 2.5 years and spent thousands keeping it running, in fact probably more than I paid for the car, and in all that time if it was left for a few weeks between uses it would throw up all manner of faults EAS inactive was one of its favourites..
FYI to clear EAS inactive fault message you don't always have to plug in diagnostics, turn the steering full left to full right and back again, this resets the system and in most cases will return your beastie to normal Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #427426 12th Feb 2017 1:12pm
Paul1234002
Thank you all for your guidance and wisdom.
I have ordered a new compressor this morning, it should be with me by Wednesday this week.
There is one thing I am curious about is that I have read numerous threads with the same issue's and it has been stated that I should change the relay too.
Does any one know the Part No for this relay or should I leave it?.
Post #427552 13th Feb 2017 11:19am
If you are lucky the relay will come with it!
When I bought my new compressor from Germany (no turtle shell) it did... .
Post #427611 13th Feb 2017 6:55pm
miggit
http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...3641.l6368
It's just a standard 70 Amp relay Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #427617 13th Feb 2017 7:27pm
Paul1234002
Air Suspension Update!!
New air compressor & Relay turned up today. Fitted and all is well.
I would again like to thank all that have commented and advised.
This is a fantastic site and the help given is second to none Thank you Guys!!!
Paul
Post #427890 15th Feb 2017 6:04pm
Page 2 of 3 <123>
