![]() | Home > Technical (L322) > L322 4.2 SC Check Coolant Level |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Had this in mine mate. I filled mine to the MAX line on the res and it has never give me that message again. I think it measures the physical level of the fluid as well as the mix (which should be 50/50 as you know).
Vergil300 Member Since: 14 Jan 2017 Location: Fife Posts: 39 ![]() ![]() |
Thanks for the advice mate!
I had some left over from an engine build i had done. Think it was just halford pink OAT which is up to spec i believe. Jordan
Development...
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Or you could have an air lock somewhere in the system from when you changed the water pump. Have you tried bleeding it? |
Yeah thought of that Kezbo, but been running it now for a good few weeks after replacing the pump, I would of thought the air would be out by now? |
The surging could just be low coolant level. Rev it with the cap off and see if the coolant stays down or comes back... Jordan
Just a thought to throw in here , when you give it the berries and the engine is warm the auxiliary coolant pump kicks in and it is possible that this is causing your surge . 2008 MY Supercharged
Tried this didn't make any difference...
So you think it is normal then? I have been looking at post: http://www.fullfatrr.com/forum/topic21436-30.html and had a look this morning, took off cap then bleed screw and the coolant did "drain down" as described here. The bleed screw had some old teflon tape on it, took it off. The level is reading way too high now, so sucked some out so it was just at the MAX level. Replaced screw and went for a drive. Had a look under the bonnet whilist the car was running and the screw is leaking, so that defo knackered and the level seems to have dropped? Sucking in air from the screw? Either way I am going to wait until its cool again and use some teflon tape or black silicone (but need to wait on that drying) and see how it goes. |
Do I think it's normal ? no but the pumps are problematic and cars around your car's age are known to have the pump wired backwards and they do also fail quite easily . 2008 MY Supercharged
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I have the same problem when giving it the gun. The coolant level has been rock steady at the max mark for months. If it is the auxiliary pump wired wrongly, is this easy to find and change round? Previous cars:
The pump is "sucking" harder if the level is dropping so cant see how being wired wrong or failing would cause this?
Might be similar to mine, air in the system? had any work done recently? Also check the dreaded screw I have been talking about. I have let the level settle, PTFE taped the screw, screwed in and filled coolant back up. If I rev the coolant still drops but I can see a air bubble in the bottle. Guessing there is air throughout the system, going to run it for a few days, try to change levels (up and down hills etc) hopfully that clears it up... ![]() |
Slight update.
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 82 ![]() ![]() ![]() |
The car should be run without the bleed screw for a long time. I did what I thought was a proper bleeding of mine (unscrewed the bleed screw for a couple of miutes), and the temperatur fluctuated because of the air in the system. I kept the car idling with the cabin temperatures on max for 20? minutes, while revving the engine from time to time. Revving without the bleed screw causes overflow so you need to do it somewhere where spilling is tolerated, and you need to keep refilling. Even after 10 minutes there were air bubbles escaping.
