Check for signs of oil underneath, have the under tray off and check the connector on the bottom of the sump.
Check the plumbing at the rear of the engine where the o rings fail for leaks
Check round the turbos
Also have a look at the state of your coolant, and the water/oil cooler in the V for leaks, see MJdronfields post re the cooler issues, bit of a common problem but you would tend to notice the coolant turning into brown liquid.
Then make sure that the car is warm flat and level when checking the oil. Preferably in the same place each time.
Mine used a bit of oil, but only about a litre every 5k. Which I'm now monitoring as I've had a few leaks plugged! There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 15th Feb 2017 6:48pm. Edited 1 time in total
