![]() | Home > Technical (L322) > L322 4.2 SC Check Coolant Level |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1400 ![]() ![]() |
the bleed screw is a poor design , an easy fix is to drill it out and tap it with a 12mm tap
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 81 ![]() ![]() ![]() |
Yes I had so much air in the system, the temperature fluctuated. I am not saying you need to have the same symptoms, but in my experience, dropping coolant level when revving the engine is a sign of air. Do you have a FBH? In that case this should probably be run also (it has its own circulation pump). I did run mine to flush out air. |
Vergil300 Member Since: 14 Jan 2017 Location: Fife Posts: 39 ![]() ![]() |
Thanks for the advice Ian, I'm glad it's likely just air...
Agreed but for £20 I can just get a new tank... |
Update.
Update on this.
Update on this... (probably related)
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
99% sure mine has had a water pump, but drove to Czech Republic and kept getting low coolant warning message on dash.
