Home > Maintenance & Mods (L322) > Reversing lights !!!!
Stew 46
England 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Hi all , looking for advice on brighter reversing bulbs , it's such a small bulb I just as well use a candle Big Cry , is there an upgrade kit ?? , stew Thumbs Up 07 VSE
Post #428120 17th Feb 2017 4:52pm
this has been done to death stew, do a search and put aside a few hours for the read.. ... - .- -.
Post #428122 17th Feb 2017 4:56pm
Stew 46
Thumbs Up think I'll just put a light bar on rear tail gate Whistle Thumbs Up 07 VSE
Post #428125 17th Feb 2017 5:10pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I originally bought 6w LED's. They gave a bulb warning and the light output was rubbish.
I then changed to 10w regular bulbs, as recommended on here, and they are much better.
http://www.ebay.co.uk/itm/160858588020?_tr...EBIDX%3AIT 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #428138 17th Feb 2017 6:15pm
javal322
2005 Range Rover Vogue Td6 Java Black
did you have any issues with the new ones creating warnings?
Post #428148 17th Feb 2017 7:11pm
Rob99
I don't suppose anyone has fitted a night vision camera......wouldn't really matter then if you left the rubbish bulbs in..... Whistle 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #428150 17th Feb 2017 7:14pm
jonnyboy54321
V8noise - presumably they dont get too hot for the fitting (I realise they aren't on for very long) /. 2007 Vogue TDV8 with 255/55/20's fitted
Post #428152 17th Feb 2017 7:18pm
V8Noise
No warnings as they are not LED's
The wattage difference is quite small, and, as you say, they are not on long so I suspect heat is not a problem. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #428154 17th Feb 2017 7:36pm
miggit
The only camera that you'll get is low light... a night vision camera is a massive lump compared with the compact things that are used on cars, I just don't understand why you lot don't want to fit LED's in your existing units.... I just wish that I could find a cheap source of lights... I could retire on the fortune to be made from converting them Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #428234 18th Feb 2017 12:58pm
miggit
The Reverse lamps are not monitored by the LCM as they are not a legal requirement Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #428236 18th Feb 2017 1:00pm
n1cktdv8
I have a small boy who lives in the boot space. When I engage reverse it sends a small electric shock to him and he opens the tailgate and shines a powerful torch. Granted it's not the best set up but it was much cheaper than anything LR provide Whistle Is this where I put the car details and a bit about myself ?........
Post #428237 18th Feb 2017 1:03pm
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
I wonder how big the minimum run would be for a Chinese copier, would be very cheap per unit!!
Post #428239 18th Feb 2017 1:30pm
miggit
The Chinese tend to work by the container load when talking cheap... the camera box is roughly 100mm x 75mm x 50mm... I'll leave you to do maths on how many to fill a 40' x 8' x 8' container... suffice it to say it will be more than ten!! Yesterday I couldn't spell Engineer... Today I are one!
Post #428240 18th Feb 2017 1:37pm
javal322
thanks for that , ill use the ones you linked above , hopefully that will help !
Post #428290 18th Feb 2017 7:27pm
jonnyboy54321
Just fitted the 10w bulbs mentioned above (which arrived fairly quickly) - straight swap - will advise whether they make a difference as and when I've reversed in the dark! 2007 Vogue TDV8 with 255/55/20's fitted
Post #429987 4th Mar 2017 6:00pm
