Home > Technical (L322) > Follow me home lights
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Heres the mystery no matter what settings I change using my IIDtool I don't seem to be able to get the FHM mode to work, there are lots of options but have tried so many combos now and still no FMH.
Does anyone have a list of working promoters from there IID tool they could share with me please.
Post #428151 17th Feb 2017 7:17pm
Trying to remember - I think you need the lights on auto then once you switch off the ignition you have to flash the headlights - something like that - I don't think there isn't an automatic function to do it every time - but I could be wrong.
Or are you already doing that sequence & still getting nothing ?
Post #428153 17th Feb 2017 7:33pm
lighthouse
I have changed the setting in the IID tool to auto and then changes the change with switch to no, added in head lights and tail lights etc but nothing works.
Mines a 2006 SC if that helps.
Post #428155 17th Feb 2017 7:36pm
rar110
I'd also like this feature on my 08 tdv8. Watching with interest. ______________________________
Post #428307 18th Feb 2017 11:08pm
this info is in the owners manual, if it doesnt work then it can be activated by a dealer or an iidtool... ... - .- -.
Post #428311 18th Feb 2017 11:13pm
SteMY06HSE
Qatar 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Hi Lighthouse,
Mine is a 2006 AJ V8 non SC and I have modified my configuration to turn off the headlights and put on the fog lights and reversing lights.
All worked fine after updating with iiD tool.
I will check the CCF file setting for mine when I get home after work this evening for you and you can see what's different.
Ste
Post #428322 19th Feb 2017 5:52am
lighthouse
thanks will be good to see what you have
Post #428368 19th Feb 2017 3:44pm
on the GAP iidtool this setting is under the LCM-light control, look for this bit,
Post #428371 19th Feb 2017 4:09pm
lighthouse
Thanks Stan
Thats the bit I have been playing with but no matter what I change no luck.
Post #428385 19th Feb 2017 5:28pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
lighthouse, It's been a while since i played with my IIDTool but i remember trying to get this to work on mine 06MY SC without any luck either. I will check mine again tonight see if i can get it working! I remember reading somewhere it isn't possible on some cars... Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #428496 20th Feb 2017 1:13pm
SteMY06HSE
Lighthouse,
Sorry for the delay in checking this, can you believe I live in the desert and its been raining solid for a week.
Anyhow, a break in the clouds meant I could check it out last night, here are the settings in my CCF which is an MY06 4.4 V8 NON-supercharged variant, and it also DOES NOT have the AUTO option on the headlights. Manual only from the switch. It was built in 2005 so it must be one of the first of the face lifted versions.
DRL: None
Front fogs off if main beam on: No
Handbrake turns off DRLs: Yes
Main bean dim with DRL: Off
FMH cancel with lighting switch: Yes
FMH delay: 40 seconds
FMH Style: Manual
FMH front fog lamps: Yes
FMH front position lamps: No
FMH High beam headlamps: No
FMH License plate light: No
FMH Low Beam headlights: No
FMH Rear position lamps: No
FMH Reverse lamp: Yes
Key in ignition warning if doo is opened: Yes
Lights on warning: Yes
Followed by a whole load of stuff on Hot and Cold monitoring of the lamps which I wont list here unless there is something you are particularly interested in.
Hope that's of some assistance for you...
Post #428733 22nd Feb 2017 5:57am
Bodsy
Fly lights work fm the LR or lights button on the keyfob.
Once enabled, you can press the button once for he front lights to come on and a second time (within 2 seconds) for the rear lights to come on.
Post #428847 22nd Feb 2017 10:18pm
ross161
United Kingdom 2014 Range Rover Autobiography SDV8 Barolo Black
I was playing with the same settings on my 2007 this evening, seems no matter what I do "FMH" does nothing. 2014 SDV8 Autobiography
Post #428864 22nd Feb 2017 11:39pm
just a thought, set the fmh delay to 40 seconds [etc] before setting which lights you want on and see if that works.. ... - .- -.
Post #428866 22nd Feb 2017 11:51pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Just ro resurrect this thread , my FMH works if i flick the headlight flash before getting out of the car and lights stay on for 40s as set but how do i get the FMH lights on for when i return to the car after pressing remote to open car. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #451324 18th Sep 2017 8:10pm
