Home > Technical (L322) > Oil level
Mike O
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Oil level
I have a 2011 4.4 V8 and tried to check the oil today but service says that "not available". what do i do as there is no manual(dipstick)method of checking the oil level?
Post #428389 19th Feb 2017 5:49pm
Baltic Blue
Wait 15 minutes then turn ignition on and retry. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #428390 19th Feb 2017 5:55pm
theres a process detailed in the owners manual,
make sure you are in park,
switch on ignition, dont start the engine,
select service menu,
select oil level display
do this when the engine oil is hot.. ... - .- -.
Post #428392 19th Feb 2017 5:57pm
