Home > Maintenance & Mods (L322) > 02 to 05 radio change to after market touch screen
daveo
heres a video of the changing you standard radio to a new singing and dancing unit.
looks quite good but make your own mind up..
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #42816 19th Dec 2010 11:25pm
dan_uk_1984
What's that unit from? Or is it a custom made replacement?
I wonder if it will interface with the Logic7 amp? Seems like an awesome upgrade if you have an HSE!
Post #42825 20th Dec 2010 12:05am
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Nice video, thank you Daveo
This unit is like this one :
http://www.autoradio-import.com/product.php?id_product=24
You can find this unit on many websites, but the problem is all the dashboard computer informaiton are not supported with this unit.
Post #42836 20th Dec 2010 10:17am
Great but what about the old display just hanging off the dashboard!!!
Post #42840 20th Dec 2010 11:56am
the old display can be permanently fitted into the glove box .. ... - .- -.
Post #42841 20th Dec 2010 12:03pm
btw, theres a few good videos from this company showing various ''how to's'' ... - .- -.
Post #42843 20th Dec 2010 12:07pm
Ok but odd that he fitted it with the connecting cable coming up in the middle of the dash!
Post #42844 20th Dec 2010 12:10pm
Fr_Raf
Because he only uses and connects the old display to set the clock
Post #42845 20th Dec 2010 12:18pm
and then tucks the socket away under the trim.......come on gaz , keep up mate. Laughing ... - .- -.
Post #42846 20th Dec 2010 12:24pm
daveo
spoke with the guy how is doing these and there may be an interface that can be used, all you will have to do is select av2 and that will connected to the factory video supply, it will show then display all the what was shown on the old display...the prob is the buttons that was on the old unit, these are now lost and are needed to control the operation of the factory system via the ibus. V8 facelift Range Rover Autobiography 22" wheels.
Post #42878 20th Dec 2010 5:26pm
SteveMFr
Site Sponsor
Exactly - it's not just the clock. You'll still need the MID. In theory it should actually be quite easy to program a working interface. These units usually run on winCE and the various ibus compatible front-ends such as CarX (which daveo has installed) or Carmedia already interface with the vehicles controls and run under windows.
The unit he's using, tho, is from an E53 (X5) I believe, and has a curved face. At the end of the video there is a very short shot with the dash cover back in place and you can see the lower edge of the unit resting on the lower dash pad instead of behind it. And it doesn't close to the wood trim on either side. You could make covers for those opening, of course, but it will never look good. And he's also mounted the GPS mouse on the dash - there are better alternatives, albeit with a bit more work. PowerfulUK has some good products and some good how-to vids. As far as I'm concerned this is not one of them.
There is a unit made for the E39 (5series) that should fit perfectly.
All you need to do is paint the faceplate foundry silver and you're done.
From all I've read on these most customers still aren't really that impressed. Still seems to be Chinese junk. Def very interesting, tho.
EDIT: I should add that I researched all of this over a year ago before gathering the parts to retrofit the oem navigation. Chinese products improve very rapidly and I'm sure there'll be a good version of this out sometime - or maybe these are already ok. Although they still have these artsy features like the pic of a '72 Chevrolet Impala convertible when you start the nav (at about 30 secs into the vid). Rolling Eyes
&feature=fvst
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42886 20th Dec 2010 6:18pm
