![]() | Home > Technical (L322) > Coolant query on a TDV8 |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269
"With the engine cold in the morning I have checked and it has dropped abit "
| SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128
Thanks
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765
Sounds like an airlock clearing. The level will vary with engine temp. Leave it alone for a while and then check it. Try not to take the cap off when the engine is warm as the system will be under pressure hence why you saw the level go up.
Ok thanks I will keep an eye on it |
oh and only check the coolant level when cold. so in the mornings is best. |
Good morning,
| jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380
Do a search on thermostat housings.
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
I would wait to see if the coolant level settles down. I think mine had some thing similar. The Indy re-bled it and put stop leak through it. This after it was flushed. It now moves between the two marks on the bottle.
Thanks for the comments so far.
coolant doesn't really cycle through the header tank, its basically just an expansion vessel. There is nothing that can't be fixed with a hammer😜😜
Thanks NMJ
never really checked to be honest Im off out in a min will see if my 4.4 tdv8 gets hot. There is nothing that can't be fixed with a hammer😜😜
👍 cheers |
coolant is pretty warm in the expansion bottle after a run out. so you might have an air lock. keep bleeding air out of the screw on the top of the expansion bottle. There is nothing that can't be fixed with a hammer😜😜
