![]() | Home > Technical (L322) > Rear Washer Jet |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
you need to remove the rear upper trim panel it just pops in but takes a fair bit levering off once off you can see the wiper motor and water hose check there first to see if you have water that far , To access the rear jet theres two ways one which i've not used apparently is to get the wiper blade vertical and then pop it off it's located at the base of the arm pointing to the side ,the other way which gives you loads of room is to remove the rear spoiler by undoing the four nuts then sliding the spoiler towards the rear and up and resting it on the roof L322 2008 vogue
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Getting the blade vertical wont help, it'll hinder, as the jet will be at it's closest to the spoiler... Best way is to fist remove the top plastic trim inside the tailgate and check that it's not a blocked nonreturn valve....
muddy_v8 Member Since: 08 Feb 2017 Location: Hampshire Posts: 20 ![]() ![]() ![]() |
Ok thanks guys will check that first didn't realise there was a non return valve in there. I had visions of it popped off a joiner half way under the carpet lol |
If it had you'd know about it cos it would be raining inside |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
This thread reminds me I have a NRV in the garage -must get around to it as Mrs JB always complaining it takes ages to get water flowing.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Good thread, mine has never worked properly.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
When I did mine I don't recall fisting anything ![]() Seriously....I removed the trims etc and did mine when I replaced the rear camera. Strip the pipes and motor off. blow all the tubes through with a bike pump and rinse through with hot water, and refit. ![]() |
Fixed mine today!!
Give me 10min and i will go and find out not sure my wife will be too happy waking her up though !! |
Yeah she normally does...... |
