![]() | Home > Technical (L322) > Steering column adjuster |
| MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471
FFRR is running great but just noticed the reach adjustment (as opposed to the up down adjuster) on the steering column is not working. The motor spins up when the adjuster level is pushed but column stays where it is. Not had a chance to check it out in RAVE but anyone know if this is common in a 2004 V8? "On first name terms with my local Dealer......now."
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
sounds like its come off the worm drive.. ... - .- -.
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Could be what mine did, the stupid plastic clip that holds the motor in place had broke in half so the motor was just dangling behind the dash.
Thanks for that - I'll have a look in the morning and see whats hanging off what |
Quick way of checking, whip either the steering column surround off or the plastic panel in the drivers foot well that the foot well light is attached to, You'll need torx screwdrivers, once they're off, you can see the motors 2006 Mercedes CLS
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
Not done it myself but i am sure i have read of someone doing this job without taking the dash apart, from under the steering colum...do some searching. 2004 black Vogue TD6 |
You can just say access it from under the dash, but it's very tricky, unless you have long skinny girly arms, which I don't |
Right - I'm off to find a long skinny girl to help me |
Got into the car tonight and the metal rod shown in the previous photos fell onto my foot |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
hi had a quick look at removing the steering cover and removed 2 torx screws but there is a 3rd hole that was deeper then my screw driver, is there a screw at the bottom of that hole.will have to look on rave,if i can get it to open
Yeah, there's 3 in total, I found the only way to get at it was to use 1/4" socket set screwdriver with an extension with the torx bit on the end, normal screwdrivers aren't long enough. 2006 Mercedes CLS
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
This just happened on mine, must have been the cold in the plastic clip.
Is this yet another example of LRUS offering recalls to customers for free whilst leaving LRUK customers to pay for it themselves:
I've just spent an hour and a bit upside-down in the footwell, my back is killing and I've barely any strength left in my arms. But I've done it. I've cable tied it together and now it works. |
| All times are GMT |
