Home > Technical (L322) > Bluetooth phone connection
s2mac
Hi
I have just agreed to buy a Vogue SE (November 06). When i test drove it, I pressed the phone button and it said something along the lines of phone not fitted. I should have asked when i got back but forgot.
Do you know if this model would have bluetooth phone connection?
If not is it something that can be retro fitted to the factory system?
Thanks
S2
Post #42893 20th Dec 2010 7:02pm
It should have both bluetooth and hard wired via the centre console so that you can fit a nokia phone cradle ...
But you first have to pair it with a relevant bluetooth phone ........
Post #42897 20th Dec 2010 7:32pm
s2mac
Thanks Mick
Ill have to look closer when i get the car but when i pressed the button for phone it did not seem to have any options for pairing etc. I was driving at te time so did not want to look at it to much.
Post #42941 20th Dec 2010 9:46pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
The car kit is passive.
You may have to disconnect the cradle in the centre console by opening the main compartment (lift the clasp, rather than pressing it down) then there is an unlock lever to enable you to remove the cradle.
Then on your phone enable bluetooth and search for devices. You should see Land Rover select it and enter 2121 once pairing is complete you should connect it- may be wise to also within your phone's options effectively 'authorise' the LR so it connects when in range.
On that model you should also have phone book over bluetooth. This retrieves the call lists and phone book when you connect.it will take a good few seconds but you'll see the phone book icon on the phone screen turn black(it's greyed out when you first connect.)
HTH
S
Post #42943 20th Dec 2010 9:58pm
s2mac
Thanks Happy
I'm not sure it has a cradle. I did not really look for it specificaly but nothing stood out to me when having a general look around. Is it 100% that this model would have bluetooth phone?
It was when i pressed "phone" on the touch screen it said something like "not installed".
Post #42946 20th Dec 2010 10:12pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
s2mac wrote:
Thanks Happy
Mine also says not installed when the Phone is not paired and connected. Pair from the phone end and you should be ok, but to be safe, do it before complete the purchase and if it does not work you can renegotiate the price a little.
Cheers
JustinP
Gone - Range Rover Supercharged 2006
Post #42948 20th Dec 2010 10:15pm
Stephen.125
You're welcome.
Yes the Vogue SE has the Bluetooth Phone (at least every one I've ever seen has!)
As above, try to pair it first.
Cheers
Steve
Post #42949 20th Dec 2010 10:17pm
If the phone is not in the cradle which is in the centre armrest it will say something like phone removed , and have you tried to pair a handset via bluetooth with the car
Post #42950 20th Dec 2010 10:18pm
s2mac
Thanks for all your help. When i get the car on Friday i will investigate further.
Post #42958 20th Dec 2010 10:42pm
You getting it from Shields by any chance .........
Post #42960 20th Dec 2010 10:44pm
s2mac
No, Just a used independent. They sent it to Shields to get some work done and then i had it checked at Strathearn. Why do you ask?
Post #42962 20th Dec 2010 10:48pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
phone book?
hi everyone, i followed this thread and managed to pair the phone but it doesnt seem to let me access my contacts, is there anything else that i need to do to my phone ? it just seems to be 'greyed out'?
cheers
andy
Post #44096 31st Dec 2010 6:02pm
There was a software upgrade that came out that allowed access to the contact directory of your phone, came out in about 2008. Chances are you don't have and the dealer will want to charge you a standard fee to upgrade your car.
It's a personal choice whether you need it and its worth paying for. Good luck. Discovery 4 HSE
1993 90 Tdi
Post #44109 31st Dec 2010 7:07pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I believe that "wigs" on this forum offers a replacement service where you get a new Bluetooth module and send him your old one. It costs £60. It should give you contacts and a more robust connection.
Post #44136 31st Dec 2010 11:19pm
As with most of above that's simply what the system displays when a phone has not been paired with the system. The car will have Bluetooth as they all have and would not have the screen you saw if it didn't.
Post #44145 1st Jan 2011 1:27am
