| Air suspension hdc issues please help | |
Hi all I was wondering if anyone could shed some light on my issues I haven't been on here for a while but read up on things with the ff from time to time I have since got another vogue as well as my RR sport
It is an 03 td6, the issues that were cropping up was abs hdc and air suspension faults I have a modis ultra (snap on) diagnostic and it was flagging up abs sensor front right hand sensor,this was changed after drilling it out and replaced with the another sensor (genuine item from Dan at duckworths) after further investigation the reluctor ring was corroded so this was also replaced with a new complete cv joint
The fault cleared but then returned so further investigation wiring loom to the sensor had continuity so no issues there, so next step was inspect abs module this was opened and found few hair wires broken sent the item away for test too ecu testing who returned the item saying it was beyond repair,so another second hand one was sourced and fitted and coded to the car with autologic
Things were OK for a few days but it reappeared so further test proved steering sensor was faulty giving corrupt degrees
So another one was fitted yesterday calibrated to the car all lights off! Bingo cracked it,,, noooo today the lights returned after a mile of driving hooked up diag and showed three wheel sensors receiving signal front drivers no show on the scope??
Reversed and it showed up drove forward it went away no signal,,live data showed height sensors within voltage parameters and height so tried new battery new alternator as voltages where low,this hasn't changed anything sometimes it's ok for an hr 2miles 30miles stop turn of key it returns,checked all ecu plugs for corrosion under passenger seat,behind battery,nothing
So after many parts being changed I still have the issue it is faulted now with front right abs sensor circuit in the abs and only one other code in the suspension can bus 50
I can clear them but this doesn't clear the lights of the dashboard
If anyone could shed anything i have missed I would really appreciate the help
Thankyou for taking time to read the long essay
