![]() | Home > Technical (L322) > Advice / thoughts please on cause of Limp Mode |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Had this with mine and it turned out to be a full DPF - had a new one done under warranty. Don't know if that helps? 2005 L322 Vogue Gold gone
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Exact same on my TD6. Turned out to be bad fuel and fuel filter. Drained tank, changed filter. All back to normal. Accept, some days your the pigeon, some days your the statue! |
cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 24 ![]() ![]() ![]() |
Ironically, we were actually setting out on a 70 mile run to get everything warm and cleared out since the car has really only had short journey (less that 11 miles) recently. Am I right in assuming that a long run will clear the DPF or will it need changing?
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
possibly split intercooler hose - common problem |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
Intercooler hoses is a distinct possibility on a 3.6 TDV8 - usually hard acceleration though & a message along the lines of Special Programs Off |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I didnt think the 2008 diesels had dpf filters and they were added to later year models! Would check the hoses but they are usually athrow loads of black smoke out of the back at the same time. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
MY2008s don't have DPF. My money would be on a split hose. Got - 2017 SDV8 Autobiography in Loire Blue
When the performance dropped off, I checked exhaust and no signs of smoke. Just very limited performance. The five mile journey to get home was done without drama, just went very slowly.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
You might need to take the hoses off to see a crack. That has been some people's experience. ______________________________
Checked hoses and no sign of splits or leaks and as the car has driven fine for the last week or so I have discounted this as the root cause of the problem.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
My money is also on the hoses.
Don't take the warning messages too literally as they are not always accurate.
OK, so I clearly didn't check the hoses properly.
Oil in the pipes is pretty normal and nothing much to worry about |
