![]() | Home > Technical (L322) > e-diffs? |
| quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 336
I believe the Rear E-diff was standard on S/C models from MY07 only and an option on all other trim and engine choices.
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
The lock symbol for the rear diff appears whether or not an ediff is fitted on the 07/08 models at least. ______________________________
| n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754
That's a bit naff....
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1432
I think that's normal, i.e. the lock symbol alternating between open and closed, when on terrain where you are just getting enough traction to maintain momentum but it's at the margin. Beyond that, when there is more wheelspin and the car is scrabbling for grip I recall another message, in yellow, in addition to the lock symbol. I don't recall feeling the lock going on/off either, though travelling on road and hitting a slippy stretch I do notice the drive being moved around to where traction is best. Only Range Rovers since 1988 |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Mostly an option - other than as stated, I think the 4.2 S/C had them as standard.
Phew. I hope the LR driver was not hurt, other than pride.
There was a Disco driver coming down the next track who must have |
Mine deffo had both symbols opening and closing padlock and changing colour....
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
The only way to know for sure is to look at the diff , if it has an actuator motor and a wiring harness |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2785
Looking forwards at the diff from low behind the vehicle, the ediff's bulging left casting is obvious when compared with an open diff's flat casting with the drive-shaft support protruding from the centre. |
Okay....we're now way into techie zone and way outside my skillset. I'll get under the car when the snow clears and take a picture |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35886
if its an E-diff then it will have a cable/wire going to it..... ... - .- -.
The main cable is at the very top and really only visible when looking directly at the top of the diff from behind the top of the left wheel, although 2 wires connect to the oil temperature sensor in the lower left housing obscured by webbing when viewed from the rear. The shape of the left housing is the most accessible distinguishing feature. However selecting rock crawl and neutral or drive to see the colour change is even easier! |
| All times are GMT |
