Home > Wheels & Tyres > Differences in actual tyre diameters even in the same size
rar110
I have two sets of tyres. Copper AT3 265/60/18s with a near new 265/60/18 Cooper HT spare, and 255/55/19 HTs. I recently swapped over the 18s for the 19s and I thought I would show the deference in actual diameter.
To demonstrate the diameter difference I used 2 ATs and the comparison tyre in the middle. I sat a piece of timber on top of the ATs to compare their height to the other tyre. Photos with rule below.
Comparison between Cooper AT 18" and HT 19" tyres. There is about 25mm difference in height.
Comparison between Cooper AT3s and Cooper HT. Both have some wear, both 265/60/18s. Same size but about 15mm difference in diameter.
 ______________________________
Post #429947 4th Mar 2017 12:48am
Is the difference between 18's & 19's a surprise ?
There's loads of web sites like this one that will tell you the difference in diameter between 265 60 18 & 255 50 19 is half an inch which is 15mm....
At 30 mph it's only a 0.5mph difference in speed though.
Some tyres bow a bit more in the middle when not under load - plus different tread depths & tyre pressures could account for some more.....
Post #429957 4th Mar 2017 8:36am
rar110
I was particularly surprised by the difference between the two Coopers of the same size. I was expecting it to be a difference of about 5mm.
It was really just a general information post to illustrate how two tyres with the same nominal size by the same maker may have different actual and so rolling diameters. ______________________________
Post #429958 4th Mar 2017 8:55am
It's a fair point - and one of the many reasons I never mix tyres Thumbs Up
Post #429960 4th Mar 2017 8:59am
