![]() | Home > Technical (L322) > Eas question.. |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I think you've answered your own question regarding the IID Tool... The data buses of the car use the instrument cluster as a 'gateway' between the different bus networks, so it's to be expected without it will cause that.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
That makes a lot of sense buddy .car was in normal height and it appeared to only be the front that raised. The whole eas systems in hard fault since I've removed the cluster . I kind of never expected it to do that tbh. Just when you think you understand this car it throws a curveball at you |
I'm not sure how true it is, but I always thought that when I get out the car and shut the door, the front will raise slightly to compensate the height difference of me sitting there... had you just got out?
I think that what it was tbh.. I was sat in the passenger seat wiring up a dashcam when it happened. Had engine on for a bit to heat myself up. Switched off ignition gets out and it then lifted. Cars has definitely been acting weird since the cluster has been removed... |
Noticed the viscous fan is on from start up and is consistently running? It usually settles down after initial start up. I'm wondering if that's linked as well? Leaving everything be just now until I get my speedo back. |
Sounds like thats what it was, don't worry too much. I know where you're coming from, with these cars you're almost waiting for something to go wrong!
Yeah v8 petrol Steve. I used ak speedo, £80 all in and back to you within a day. Really good guys to deal with as well. I figured the fact the interiors in bits just now as I'm fitting piano black wood ect I would fix the speedo and fit a dash cam at the same time so made sense.. |
Sorry I can't help with that then mate, v8 will be my next car however |
Aye definitely mate. I couldn't even remove the front lens from mine let alone install a new ribbon |
No worries at all mate!
Cluster refitted and cars behaving normal again. Fans at normal speed so i presume the cluster being removed has upset the kbus, can bus system to some extent and made it go mental. Eas is as how it should be as well. |
Glad to hear it mate |
