Home > General > DIY FBH
SteveMFr
Site Sponsor
dan_uk_1984 wrote:
I believe you can get a block heater for the Jag engine? Then you just plug in every night with a weatherproof socket by the tow bar or something... run it on a household timer to kick in an hour before you set off in the morning...
A cheaper alternative might be the Kenlowe electric heater that Dan had last year. It sits in the coolant circuit (heater circuit actually) and functions the same as a FBH w/o the fuel and the burning (uses mains power) so it can theoretically be installed on any car.
What did you do with yours, Dan? Did you ever install it (does it work well)?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42996 21st Dec 2010 8:31am
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Our wake-up alarm went off this morning and I forced my eyes open remembering the heater, I pressed the button on the remote switch to turn it on, then went straight back to sleep for a few more minutes kip.
I awoke 10 minutes later feeling rather pleased with myself for not forgetting to turn on the heater, I went downstairs to get some breakfast and discovered that I had actually turned on the Censored Christmas tree lights.
So the heater was only on for about 15 minutes, but thankfully that was long enough to defrost all the windows, and more importantly unstick the frozen doors.
Cheers
JustinP
Gone - Range Rover Supercharged 2006
Post #43007 21st Dec 2010 9:43am
i was feeling pee-ed of about the cold and snow this morning , but i read your bit about 'turning on the xmas lights by mistake ' and this has made me laugh..excellent. Laughing ... - .- -.
Post #43009 21st Dec 2010 9:47am
dantheman
letsavit2 wrote:
dan_uk_1984 wrote:
dantheman wrote:
dan_uk_1984 wrote:
scarey wrote:
interesting, but it wouldnt work if you lived at the top of a block of flats [unless you had a very long lead]... Very Happy
Who owns a Range Rover and lives in a block of flats? And surely if that was the case it would be a cheap oil burner with the FBH fitted as standard anyway!
Err... I do... Smile
Really? How quaint.
dantheman going come back now and tell you its a penthouse in kensington.. Laughing
For flat owners
http://www.dry-it-out.com/inverter-5006-3k...-free-fuel
dont tell your insurance company... Whistle
Laughing If only it was a penthouse! Nothing quite so grand I'm afraid - just a quaint little flat for work - perfectly functional, as bang on the Quayside/city centre and only a short drive into work. The estate agent was clean out of 19th Century cottages or farmhouses with detatched stables I'm afraid Dan... Embarassed
And I do hope the gent with the TDV8 along from me doesn't read this and is upset by the cheap oil burner remark...
Post #43011 21st Dec 2010 10:09am
You can just see the 15kw FBH I have in the reflection
The garage is at around 10c so no problems with the cold weather Thumbs Up
Post #43020 21st Dec 2010 11:09am
Some Dirty B Censored d draw a big Lumi arrow on your car John ..... Laughing Laughing Thumbs Up
Post #43041 21st Dec 2010 12:50pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Re: DIY FBH
JustinP wrote:
It was -10 in Cambridge today
I saw -12oC on the dash as I drove from Cambridge to Royston yesterday.
Post #43042 21st Dec 2010 1:08pm
I was up your neck of the woods an hour ago Mick....WTF are you lot doing it was -10c up there at 11.00
Post #43043 21st Dec 2010 1:37pm
Martin
Site Admin
The 4.2 SC and Jag 4.4 V8 block heater is part number 3601559
Post #43046 21st Dec 2010 2:27pm
iT LAD
Laughing Laughing Laughing
Post #43048 21st Dec 2010 3:11pm
dantheman
Apparently around the Liverpool area, temperatures lower than -17 degrees C were recorded last night... a tad chilly!
@47p2: Wouldn't have thought that you'd have enough trouble to warrant a FBH with your car being in a garage. Mine is fine being in secure underground parking when in Newcastle - no frost/ice and starts on the button. Down here in Burnley also fine under a carport (apart from the dvrs door lock freezing on me the other day, but a minor problem nonetheless).
Post #43073 21st Dec 2010 5:43pm
dubbs
United Kingdom 2007 Range Rover Vogue SE Supercharged Buckingham Blue
My SC has some form of FBH on it. I n the menu I have an option of timed climate plus I have another remote fob to turn it on.
During this weather I've turned it on 15-20mins before going out and the car has been nicely warmed.
Will it be the webasto one?
Post #43114 21st Dec 2010 10:25pm
