![]() | Home > Maintenance & Mods (L322) > TDV8 oil removal |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
Presumable this is only suitable for engines that have a dip stick. They seem to be gradually be going out of fashion. None of our 3 cars has one! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
The 4.4 doesn't have a dipstick but does have the tube which you connect the sucky bit too, it's how they do it in the MD! There is nothing that can't be fixed with a hammer😜😜
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
y Hi it comes with 3 pick up straws. One is 6mm OD, and about 900mm long One is 8mm OD, and about 750mm long. This a flexible steel straw coated in plastic. Looks very similar to a piece of curtain wire One is about 10mm OD and about 300mm long, used for axle oil etc. You can use it on any engine simply by inserting a straw down the dipstick tube. I am going to try it on my D1 300Tdi next time. Then I plan to extract the diff oils out of the L322 Like mentioned in the other reply the 4.4L does not have a dipstick, you check the oil on the dash electronically. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1667 ![]() ![]() ![]() |
Hi Macca
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
I'm trying to work out where you suck the oil from in the first picture? |
look at the engine, the pipe is towards the front drivers side, about 9" - 1' back into the engine bay. it has a black plastic cap on it which 1/4 twists and pulls off.
Got it, perfect !!
Just to correct my earlier comment and to answer Maccas PM - my compressor was not a bog standard ALDI one it was a bog standard SCREWFIX one. Name on the side of the tank is Sumo and the model number is OL195/24 CM1.5UK (first O might be a Q).
