Home > Technical (L322) > Engine Management Light - Supercharged
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I have been driving round with my engine management light on for nearly 8 years. Initially the dealer replaced all sorts of sensors and gadgets and then said the cats were knackered. However, as I was happily clearing the MOT test thresholds, I decided to ignore it. I then visited a local independent who offered to sort it out at a cost of £1,000 plus parts; an offer also ignored.
Since then I have deeply resented the incessant glow of the orange light, a constant reminder that I was probably wrecking my motor, but resigned myself to it. Until now! Armed with my new IID tool, I started to become obsessed with clearing fault codes. I read up on the relevant codes and set out to sort it out the light myself - one day.
Recently, on removing the engine cover to do a few jobs, I noticed that a small insignificant rubber tube had been bodged up. This turned out to be the Full Load Breather Hose (Item 3 below).
It was a home made job wrapped in tape which concealed a broken plastic connector:
So I ordered a new one from Dan for £28 (LR003383), fitted it and cleared the fault. The light went out as it usually does, but, despite all sorts of engine abuse, it has remained extinguished. In the past, it has come back on after about 10 miles following clearing the fault.
Can that be it?
Driving has become a dark and lonely experience. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #430150 5th Mar 2017 9:36pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Well done you Thumbs Up 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #430153 5th Mar 2017 9:45pm
dingg1
yes , those pipes are the source of most lean running codes , pulling in unmetered air , especially where the hose connects to item 1 (in my case)
Post #430167 6th Mar 2017 12:09am
rar110
Well done.
Thumbs Up ______________________________
Post #430222 6th Mar 2017 2:00pm
