Home > Technical (L322) > 4.4 TDV8 Bonnet open
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all, the last few days only every now and then the FF has been telling me the bonnet is open. I have checked it but it's not and shut sound.
If you drive off after 20/30 yards the dash clears and all fine for a few days.
On Sunday the car was on the drive and the alarm sounded, I opened and locked again but would not lock, just two bleeps and would not lock. Left her for 20mins locked fine and all good.
Any ideas ? Sticky bonnet sweat switch may be.
Thanks Dave
Post #430250 6th Mar 2017 6:51pm
switch or latch....mine sometimes needs a further 'click' to make sure its fully closed... ... - .- -.
Post #430252 6th Mar 2017 7:06pm
Dogfishdave
Thanks Stan, I will check it out.
Dave
Post #430253 6th Mar 2017 7:11pm
rar110
The plastic bracket holding the switch may be broken allowing the switch to drop and causing the bottom on the switch to not be fully depressed. ______________________________
Post #430299 6th Mar 2017 10:16pm
Webbie
If I let my bonnet drop from about eight inches it latches fine. If I push it shut, the dash warning comes up once I start moving. Guess which method of closing it I use.
Post #430302 6th Mar 2017 10:26pm
Dogfishdave
Thanks lads, I will check it out at the weekend, just finished work Sad
Post #430402 7th Mar 2017 8:55pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I had the same issue on my 4.4 tdv8. I gave the switch a good spray with wd40 and no more issues.
Post #430430 8th Mar 2017 9:31am
