Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Well, I still haven't done the spark plugs. First MOT tomorrow and am nervous! One headlight is a little reluctant to start and the handbrake is a bit weak, but we'll see. The same place does alignment so I'm getting that done too. |
27th Oct 2016 7:32pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7917 |
Good luck mate... Pete
27th Oct 2016 9:12pm |
Just had a call... and....
28th Oct 2016 2:16pm |
I have an MOT, and the 4 wheel alignment has definitely made tight corners ore comfortable. Can't wait to get it above, er, 60 or so and see if the slight shimmy has gone.
28th Oct 2016 5:41pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
The slightly off steering wheel that you got used to is now straight, now you have to get used to that! The driving pleasure is enhanced, hope the shimmy has gone. |
29th Oct 2016 7:29pm |
Just a follow up... the wheel was still slightly off, and I'd had a slow tyre leak diagnosed as a leak at the rim. But, after the alignment I started getting a 'clonk" on some uneven tarmac. Took it back yesterday, diagnosed a knackered track rod end and noticed that they'd actually fixed the leak on a wheel that didn't have a leak!
25th Nov 2016 4:17pm |
Don't be silly... plenty more is waiting, just waiting for that time you think, this car is going really nice now, then
25th Nov 2016 7:54pm |
No bong today. Well, key battery low, but it's kind of new. However, after having a kangarooing fit yesterday while running on petrol (OK on LPG) it wouldn't start this morning. No codes.
6th Mar 2017 3:12pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3063 |
May be only the saddle tank pump - do u have more than 1/4 tank of fuel in?
7th Mar 2017 11:59am |
Confirmed as the in-tank pump. I don't have the time to apply the lower cost fix of an X5 pump, so will just have to swallow the cost. BRC system has ho way to force an LPG start that I can see. |
7th Mar 2017 12:08pm |
Today's fun. I'd noticed that the brake dust shield on the nearside was a bit rattly when I changed the strut. So today I popped the wheel off, removed the caliper, removed the disk and bolted the shield back on with some penny washers. Very easy job, helped by the recent disc/pad change so all bolts were easy to remove!
18th Mar 2017 12:09pm |
In the slightly warmer weather a few weeks ago I noticed the air con wasn't particularly cold. My local garage does a £21 regas through Groupon for sub-3L cars, so I called them and agreed that price for my 4.4. An hour later and I have ice cold a/c again!
9th May 2017 2:04pm |
9th May 2017 10:49pm |
Hi, sorry I didn't reply. The fuel pump was supplied by the specialist, probably a factory LR one as they use genuine parts.
10th Oct 2017 11:04pm |
