![]() | Home > Technical (L322) > Metallic Rattly noise on hard acceleration 4.2 S/C |
Maybe the engine pinking? |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Could be one of the cats is breaking down internally? Current Fleet:-
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 332 ![]() ![]() ![]() |
No i don't think so it's not that sort of noise thankfully. And you would expect it more in higher gears. 2005 E60 M5 2017 L405 5.0 AB 2024 i7 xDrive60 -------- 2006 (MY07) L322 4.2 S/C, 2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE. |
That is where I was thinking annoyingly. 2005 E60 M5 2017 L405 5.0 AB 2024 i7 xDrive60 -------- 2006 (MY07) L322 4.2 S/C, 2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE. |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Exhaust heat shield? Bish.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
From your description , it sounds like the noise is only apparent when the supercharger is really doing its stuff .
I dont think its supercharger related to be honest, mainly as it doesn't occur in higher gears. If it were S/C related it would be there in every gear at a certain RPM etc. I had to "make use" of the power plant this weekend a couple of times - dawdling tourists between Glencoe and Loch Lomand required some committed multi vehicle overtakes!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
theres a few heat shields under there, in and around the transfer box as well. get under there and tap them all to see if any are loose or catching on something. Its likely to be a heat shield i would think. I had one making a bit of a buzz on mine, couple of mins under it had found it and bent it back into shape. |
