Home > Maintenance & Mods (L322) > Coil pack
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
Coil pack
G,day, can anyonehelpwith a coil pack problem, my 2004 4.4 has an intermitant missfire at idle speed, this is slowly getting worse and today i even experianced loss of power under acceleration. How can i identify which cylinder is missing. All advise is appreciated. Big Cry
Post #430445 8th Mar 2017 12:09pm
CS
Could you turn the engine off when the problem is manifesting itself, take the plugs out and see which are wet with unburned fuel? I recall doing that with a RR Classic when there was a coil short problem, alas some of the plugs could not be shifted. I expect there is a more sophisticated method using a meter on the electrics, or plugging into diagnostics. Only Range Rovers since 1988
Post #430468 8th Mar 2017 4:20pm
holidaychicken
As CS says, take all your plugs out to look for an odd one and then swap the coil pack with a plug that looks good and see if it moves and diagnostics with live data like a faultmate will give you a roughness value for each cylinder
Post #430524 8th Mar 2017 11:59pm
Chasazim
Thanks for the replys, but the miss is irregular and buy the time i let the engine cool down and get the plugs out i may not see any difference. I have the iidtool but that doesn,t show anything. I have one new coil pack and i suppose i could swop it over with No. 1 plug and then No. 2 and so on, but that would be a real hit and miss(no pun intended). Rolling with laughter
Post #430530 9th Mar 2017 12:58am
holidaychicken
If a cylinder has been behaving badly for a while you may see a difference in the carbon deposit on it rather than it just being wet as i think the injector is turned off for the cylinder that isn't sparking, I only read that somewhere so not sure if that is true though ...
Post #430542 9th Mar 2017 7:53am
Chasazim
Thanks for thecomment, i am going to have a look today, just waiting for the motor to cool down a bit, took it for a good run around town and no miss but i get the shivers each time it does so i will dig deeper
Post #430544 9th Mar 2017 8:11am
