Home > LPG > LPG not switching over
Pluribus
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi
I've got a BRC system in my 2003 petrol L322 Vogue. It worked fine when I purchased it a few weeks ago. I refueled with a full tank of LPG but it is refusing to switch over to gas. It will just beep for about 10 mins as if its empty, them if it does decide to switch, the engine immediately cuts out and I lose all power until I turn it back to petrol again.
I've got the same system in my Freelander so I'm well used to it, I've just never had this problem before.
The car was recently serviced and all fluids were changed. It has a full tank of lpg and a full tank of petrol. The fill indicator on the LPG switch shows it's full as does the gauge on the tank.
My local LPG guy wont work on a system thats charged as he has no filtration in his workshop so I would like to try and sort this out before having to purge a full tank before taking it over to him...
Does anyone have any ideas?
Post #430712 10th Mar 2017 5:25pm
dingg1
ask here
http://lpgforum.co.uk
if your man won't look at it with gas in the tank - find someone else IMO
my 'guess' would be solenoid operated valve stuck shut at tank
Post #430716 10th Mar 2017 5:43pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Agreed on the solenoid valve.
They get clogged up with deposits from the gas so I'd say this is the likely cause. 2012 Westminster 4.4 TDV8
Post #430719 10th Mar 2017 6:04pm
Pluribus
Thanks, I'll post over there now.
Post #430720 10th Mar 2017 6:04pm
Pluribus
I've not had to do this before. How easy are they to change? Is the solenoid valve easy to access?
Post #430721 10th Mar 2017 6:25pm
Pluribus
I've just been out to the car and the engine management light came on. Read the fault code with Torque and it said O2 sensor heater circuit malfunction (bank 2, sensor 1).
Could this heater circuit have anything to do with it as I know it must be a certain temp before the gas will switch. I've not had any cause to use the heaters since I got it so no idea if they were working or not - but this is the first time the engine light has come on.
Can I fix this problem myself or do I need the LPG guy to do this also?
Regards
Ian
Post #430724 10th Mar 2017 6:37pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
There is a little filter in the pipeline under the bonnet, if that is not replaced every 20 k it might block. Bear in mind I'm a non tech.
Post #430813 11th Mar 2017 5:54pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
did you get sorted?
Post #442331 22nd Jun 2017 7:57pm
Pluribus
Yes I did, and I apologise for not updating this forum. I hate it when people do that!
It was both the solenoid and the wiring to the vaporiser under the bonnet. The idiot (I mean professional installer) decided in his professional opinion that the best place to install that wiring was along the rear wheel well where a clip failed and left the wiring chafing against the wheel. It had split one of the wires so no signal was getting through to the solenoid.
If it hadnt been for the excellent work of my favoured installer (Neil of Medway Dual Fuel), we may never have found it.
All up and running, he even gave it a remap as part of the service.
Post #442446 23rd Jun 2017 5:16pm
Lukie
Good to hear all is well
Post #442476 23rd Jun 2017 9:13pm
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Glad you got it sorted
Post #443723 6th Jul 2017 2:35pm
