Home > Technical (L322) > Hazards not flashing when locking and unlocking l322
S14WNO
Its been like this since i got the car a few weeks ago. When i lock and unlock the car i get no hazard flash at all, a second press of the lock button does nothing so i cant even put it into deadlock. I sometimes need to go back and check to see if the car has actually locked or not. Had a search around and found nothing to help me... anyone any ideas?
Post #430833 11th Mar 2017 7:59pm
proser
Generally needs coding to enable flashers etc. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #430849 11th Mar 2017 9:39pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
There's no need to press the lock button twice as superlocking and perimetric alarm is active with one press, the only reason to press it twice is to superlock all doors and activate the perimetric alarm, but NOT activate interior space protection and tilt sensor.
The previous owner may well have turned off the flashing indicator for some reason, it's easy enough to enable sound when locking etc with the IIDtool.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #430852 11th Mar 2017 9:51pm
S14WNO
So i will need to get it plugged into diagnostics to code it?
Post #430910 12th Mar 2017 10:55am
UK Marine
It's a dealer only procedure unless you have an IIDtool then you can customise it yourself.... Thumbs Up ______________________________
Simon
Post #430914 12th Mar 2017 11:37am
S14WNO
May have to invest in the iid tool then
Post #430918 12th Mar 2017 12:11pm
UK Marine
There are loads of threads on here about the IIDtool, they may be pricey but they save money even in the short term.
Those of us with roverphobia wouldn't do without one Very Happy Thumbs Up
Simon
Post #430921 12th Mar 2017 12:19pm
I had the lock / unlock without the hazards flashing, turned out the upper tailgate wasn't fully closed when I locked the car even though it looked fully closed. Opened the tailgate shut it purposefully and everything ok again. Worth a try. Thumbs Up
Post #430922 12th Mar 2017 12:45pm
S14WNO
Saying that, how does your lower tailgate work?? I have to flip like a switch on each side for it to be able to close... and i though my upper tailgate wasnt closing properly. Have to check that out
Post #430951 12th Mar 2017 6:28pm
My lower tailgate locks fine with the electric locking, you should't need to operate the lock catches by hand. One of my lower tailgate locks didn't work initially which I corrected by moving the body latching plate towards the rear of the car a small amount.
Post #430953 12th Mar 2017 6:45pm
S14WNO
See mine doesnt lock like that, this is my first range rover so didnt know any different...
Post #430957 12th Mar 2017 7:56pm
Sorry I have misled you. Embarassed
When you close the lower tailgate the latch at each end of the tailgate latches over the body locking pin.
You can simulate this with the lower tailgate in the open position by pressing a screwdriver shaft into each latch in the position the body locking pin normally goes on closing. There should be a pronounced click as the latch operates.
My latch didn't work correctly due to the body pin being too far forward such that the latch simply couldn't lock over it.
Unlocking is operated by the recessed button mounted on the top of the tailgate.
When you press the button you should definitely hear the two locks on the tailgate unlock.
Post #430979 12th Mar 2017 10:10pm
S14WNO
Yes i can hear it unlock when i press the button but its closing it afterwards... i have to click back the notches on each side to be able to close it, it doesnt close electronically. The guy i got the range rover off told me this is how its meant to be done and showed me what to do, said he didnt know how to do it either when he got the car but i think he was playing dumb as i have found a lot of issues that he wouldnt of missed after a long period of time owning the car, one being the suspension (he told me he thought it went up and down on its own when you went onto the motorway and he didnt know you could control it via the dash control) i guess im more of a mug for falling for his sh** to start off with lol. If i get a break from my 11 month old tomorrow i will look at taking the mechanism apart and cleaning it up the best i can... see if that does the trick. Im hopibg this could be the reason my lights are not flashing
Post #430983 12th Mar 2017 10:21pm
mjdronfield
On my td6 I had one side that was sticky, I just loosened it with some WD40... that said, the electric bit was working.... you can hear it try when you press the recessed button.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #430985 12th Mar 2017 10:41pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Superlocking
Or deadlocking...
Required 2 presses on some models.
For example on mine. To deadlock it needs 2 locks.
Post #431006 13th Mar 2017 7:08am
