![]() | Home > In Car Electronics (L322) > Using non DSP amp with Logic 7. |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I think my DSP (2004) has partially died. I have right rear speakers and left lift gate speaker. The left rear door speakers have rare crackle as does the left lift gate. Currently I have the Logic 7 disconnected. If I connect it I can get this pulse thumping ( think helicopter) from front door speakers. No other sounds then.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
I think you'll have some problems there Bud, the dsp amp drives each speaker separately, apart from the centre dash, so your looking at a 10 way + sub pre out on a std DSP set up and I think the logic 7 system has more speakers |
Thanks. Here I thought coding was a theft protection thing. I assume that if my DSP is faulty I won't be able to determine if the Logic 7 amp is working until I get a known working DSP. Hmmmm in for a penny might mean in for a pound. Might be better to sell the working parts on eBay to pay for the Android unit. |
It's a definite improvement over the stock system.. with better screen resolution |
I find the fix-it board on eBay for the no sound bad amp chip in the bm54. Am I correct this is the radio amp? Are all sound sources dependent on passing through the bm54/radio amp before going to the 2 Logic 7 amps? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
It's the amp for the whole system....just happens to also have the radio in it too. The DSP gets called an amp but it's not, it's a sound processor with active crossovers. 2011 Range Rover Vogue SE 4.4 TDV8
Well then that explains everything. I'll try the $69 fix. Thanks. |
If that doesn't work there is a member on here called Baris who repairs and upgrades them.... he should at least be able to diagnose if you PM him, and then you can decide what you want to do.
![]() Yes the BM54 has an amplifier built in to it along with the radio, and I believe that on the lesser models this alone powers the speakers.. So either could be at fault... any chance of borrowing a working BM54 off some one and testing it in your car.. at least you'd know which bit needs changing. But i suspect that as you getting a radio display of the screen it's the DSP that's fubar'd ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
You must have different info to me then.... I've had both the stage 1 and stage 2 upgrades to the BM54 internal amps, no mod needed to DSP. The DSP simply acts as an active crossover once it's done its processing. It needs power to run the crossovers, so they are not driven by the BM54 - freeing up power..... I have info somewhere.... so yea, either could be at fault as miggit says, as if the crossover on a channel feed is stuffed, you will still not get sound, even if the BM54 feed was good.... 2011 Range Rover Vogue SE 4.4 TDV8
Crap. Back to probably not worth it and better investment to do the Android upgrade. Moisture not looking like a big deal. The floor of the area just has some minor surface rust about 6 in x 6 in. The DSP to Logic 7 auxiliary amp connection was fairly corroded but nothing on any internal workings or any circuit boards. Thought maybe the corrosion caused a short and took out anything anywhere. |
I think that the DSP is crossover and amp for the bass, which would explain the rather hefty wires coming from the unit... if you look at a lesser setup the speakers are wired straight in to the BM54... and as far as I know there is only one BM54 for the ffrr.
OK now I have seen "DSP display" a couple of time. I don't ever recall seeing anything on my screen that says DSP. Perhaps mine has.been dead from PO. |
The BM54 is the radio/pre amp, the dsp is a much larger unit, black and has a lot of wires coming from / to it, and is the unit closest to the rear light. Yesterday I couldn't spell Engineer... Today I are one!
