![]() | Home > Maintenance & Mods (L322) > Tinted windows warning !! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I must admit, I'm with you rvbush, I do smile at the Range Rover vans.... and my Buckingham blue has factory tints.....
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 568 ![]() ![]() ![]() |
Unnecessary quote removed
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I'm not massively keen on them, but had the rears done on mine due to young kids in the back which as worked.
Harley? Is that one of those things that fire once every lamp post? Drives:
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Getting back to the original problem...... If a fault has occurred within 6 months of your purchase it is the garage responsibility to prove it was not there at time of purchase. So if you have had the vehicle less than 6 months the garage should fix unless they can prove otherwise 56 TDV8 Vogue SE
