Home > In Car Electronics (L322) > Battery system running a couple of dash cams?
GGDR
..yes exactly why I much prefer the power bank idea.
. Cheers, Greg
Post #431241 15th Mar 2017 7:47am
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Ah got ya!
I'm agree with you on the power bank rather than another battery! I have an 0801 camera already fitted in the car. The connection is a mini USB. I've also got a large USB power bank knocking around here somewhere. Use it for holidays to charge phones etc. Can't Remember spec but was quite large one.
Gonna dig it out and try it today as a test run before buying bits and ripping car apart Accept, some days your the pigeon, some days your the statue!
Post #431258 15th Mar 2017 10:12am
Boydonegood
Just had a quick look.
The one I have is 13,000mAH Anker unit. Was quite expensive when I brought it a few year ago.
Has 2 USB out 1A and 2A. And mini USB to charge.
Will have a try see how long it lasts.
There's a guy selling a wiring kit on EBay. Neg and Acc live in (fused) and a 3m mini USB out for £8.. I know it's dear for an empty box but by time I buy a 12v lighter socket and USB to lighter socket adapter I may as well grab his kit. Accept, some days your the pigeon, some days your the statue!
Post #431259 15th Mar 2017 10:29am
GGDR
Brilliant if you can test to see how long your 13000 would run a camera.
Can you post the eBay link?
. Cheers, Greg
Post #431349 15th Mar 2017 9:00pm
Boydonegood
Haven't had chance to try power pack yet as a knocking coming from steering has taken lead in "jobs to do"
But here is the link
http://www.ebay.co.uk/itm/132098013652?_tr...EBIDX%3AIT Accept, some days your the pigeon, some days your the statue!
Post #431553 18th Mar 2017 9:51am
GGDR
Done a bit more window shopping on this...
Thinking about either of these camera systems :
https://www.amazon.co.uk/ACCFLY-Degree-Rec...+rear+1080
or
http://www.ebay.co.uk/itm/2-0-I1000-Full-H...Swr~lYtDPx
Not the expensive end of things but:
Both are 1080p, two camera sets. Night vision, wide angle cameras with loop recording and shock sensor.
At this end of the price scale I could have the set up I imagined at the outset: dual cameras with the extended recording supplied by the USB Maplin (or other) powerpack. All for under £100...
Any thoughts appreciated...
. Cheers, Greg
Post #431615 19th Mar 2017 9:42am
GGDR
Or two separate cameras, these 1080p Motorolas ar two for £99 at Argos right now:
http://www.argos.co.uk/product/6553393
EDIT: wait these don't have night vision, strike this Cheers, Greg
Post #431616 19th Mar 2017 9:47am
GGDR
...and this power pack has 12v input and USB out.
https://www.amazon.co.uk/Aidudo-Emergency-...h&th=1
So I am thinking this would charge when ignition on and the cameras just run off that..
.. Cheers, Greg
Post #431621 19th Mar 2017 11:08am
GGDR
Hi boydonegood, don't suppose you did a test running a camera off your Anker 13000?
. Cheers, Greg
Post #432913 27th Mar 2017 10:40pm
