Home > Technical (L322) > Restricted Performance After Fuelling
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi All,
Heading down south this morning. Left when it was snowy, car was great feeling happy I own a FF! Anyway. Got to Junction 38 on the M6 to fill with fuel. I was a little low by that point and put 100 litres in (I know it shouldn't get that low but it was cold outside).
Got 15 miles down the road and the restricted performance light appears and it does as it suggests. I pulled over, cleared the fault only for it to return a few seconds later. Idle is very rough and it is mis-firing. I have attached a pic of the OBD readout, It was the fault at the bottom that appeared first and seemed to cause the rest.
Anyway, I had it recovered to a local garage and there it waits for them to look at it. Any ideas on what it could be would be appreciated.
Post #431945 21st Mar 2017 6:13pm
crank or cam position sensor up the duff possibly leading to a mismatch in the readings. There is nothing that can't be fixed with a hammer😜😜
Post #431949 21st Mar 2017 6:37pm
Mcnallykev
I have given the garage the readings hopefully it's nothing too expensive!
Post #431954 21st Mar 2017 7:09pm
Mcnallykev
Update for the Garage. They think the timing chain has slipped?? Is this common/possible? I think it is the Bank 2 Cam 2 sensor. If they replace that then see if the fixes the rest of them.
Any suggestions welcome.
Cheers
Kev
Post #432411 24th Mar 2017 10:56am
i know the 5.0 suffers with a front end rattling, maybe this is associated? ... - .- -.
Post #432416 24th Mar 2017 11:45am
Mcnallykev
It has rattled since I have had but did the usual checking on forums and it seemed to cause no issues. The car hasn't missed a beat before this happened and there was no sign of it happening. I still think its a sensor and the garage aren't really sure what they are doing.
Post #432420 24th Mar 2017 12:31pm
Mcnallykev
Anyone had a timing chain replaced? How much did it cost?
Post #432443 24th Mar 2017 3:48pm
Rob99
I would have expected some other damage if timing chain had slipped so my first thought would be camshaft sensor.
Always start with the obvious and cheaper items...... Very Happy 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #432444 24th Mar 2017 3:51pm
Mcnallykev
Thats what I thought but he says it is off 32 degrees
Post #432445 24th Mar 2017 4:00pm
Mcnallykev
So, After no car for a week. The specialist has had a look on their systems and it would seem something has slipped as all sensors are providing readings. Going to do a compression test to check they Cylinders are ok and then set about opening her up to have a check what has gone wrong.
How much have people paid in the past to get the timing chains/tensioners done?
Post #433670 3rd Apr 2017 1:56pm
alistairh
I've just been quoted £1800 for chains, tensioners ect and cam cover gaskets and a couple of other seals..thought that was reasonable for the amount of work involved 👍
Post #433672 3rd Apr 2017 2:01pm
Mcnallykev
Thanks Alistair,
Sounds reasonable. Was that at an Indy?
Post #433674 3rd Apr 2017 2:27pm
Dolphinboy
My 4.4 BMW v8 petrol recently had the chain guide and chains and gaskets done at a LR indie. £3k Inc vat.
Post #433722 3rd Apr 2017 6:33pm
Mcnallykev
Cheers. Just have to hope there is no cylinder damage!
Post #433726 3rd Apr 2017 7:03pm
This may give more info
http://www.fullfatrr.com/forum/topic36232....p;start=15 There is nothing that can't be fixed with a hammer😜😜
Post #433731 3rd Apr 2017 7:16pm
