Home > Maintenance & Mods (L322) > Rear washer not working
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Rear washer stopped working a couple of weeks ago, so obvious reason ......frozen
All the snow disapeared, but still no water, so I tried a pin in the jets.....nothing
Bought a new rear wiper arm from the stealers yesterday, fitted it today.........still no water
Removed the pipe and none return valve and Im not getting any water through from the front but I can hear that the pump is working
Im now totally stumped Big Cry
Anyone got any ideas please?
Post #43050 21st Dec 2010 3:31pm
snow's gone but its still cold..the pipe is probably still frozen.. ... - .- -.
Post #43052 21st Dec 2010 3:39pm
Tesh
You were right Scarey......... its working perfectly now Very Happy
Post #43220 22nd Dec 2010 8:18pm
result Thumbs Up ... ... - .- -.
Post #43221 22nd Dec 2010 8:20pm
dan_uk_1984
You should increase your screenwash concentration...
Post #43228 22nd Dec 2010 8:38pm
Tesh
Im trying to but cant find any decent screenwash in stock in the north east
Post #43258 22nd Dec 2010 9:58pm
Andy
Mine is playing up too. When I push the stalk, I can hear the motor, but its intermittent. I suspect the stalk might be at fault. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #43584 25th Dec 2010 2:13pm
oodathort
whats involved in changing rear wiper arm is spoiler in the way ?
Post #43586 25th Dec 2010 2:18pm
Tesh
Its fairly easy
Remove the upper trim from the inside of the rear hatch, you then need to unscrew 3 bolts (10mm) holding the rear spoiler.
Close the upper door and stand on the lower, take hold of the spoiler ahd slde it back towards you.
It is still attached by the brake light wire but you have enough play to rest the spoiler on the roof.
Now you can get at the wiper arm Smile
Post #43655 27th Dec 2010 11:01am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
.... and refit is far simpler .. for the spoiler at least if you leave the wiper in the centre of the screen. I.e. let it get mid wipe, then switch off the ignition. At least I found it half the faffing that way. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #43678 27th Dec 2010 1:35pm
