![]() | Home > Technical (L322) > Seat belt chime no chime and seat belt light goes out |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Hi,
Louismacrides Member Since: 18 Mar 2017 Location: Weston Posts: 69 ![]() ![]() ![]() |
Hello when u say not in use can you turn it off . It never chimes no matter what on seat belts |
I've only had her 2 weeks |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
As standard they chime, it can be disabled, and is by many, and there is a post somewhere with how to do it, it is a plug/unplug the belt thing. Not sure if it's just the reverse to deactivate it tho.
Hello I have tried this no luck and everything seems still plugged in but I will recheck |
Mines never chimed when the seat is occupied but the seatbelt is unbuckled. I've had a look with my IIDTool and can't see the option to enable or disable a chime...... is this not just for the later models?? ______________________________
That would explain it . If they just don't do that on 2004 models |
That's a fair point, I wonder if the bong was for ford era cars. There is nothing that can't be fixed with a hammer😜😜
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
My 2004 chimed if the seatbelt was not on. Only Range Rovers since 1988 |
I will keep looking and reading . I notice fuse 37 was missing . Fitted it with no luck . Looked it up it says transfer box and towing operation |
I'll have a go down the farm track tomorrow not wearing my seatbelt just to see if you need to be moving to activate the chime. Other than that mine might be faulty because it's never chimed all the time I've owned it... ______________________________
Thank you |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 628 ![]() ![]() ![]() |
My 2012 chimes as soon as you move off if any occupied seat belt isn't buckled. I also looked with the IID tool to see if I could switch it off but haven't found where yet. Grateful for pointers if anyone knows please... Mike - MPx
Sit in car
