Home > Technical (L405) > Front Cool Box
AMTony
Front Cool Box
Any ideas what should be expected?
Put bottle of water in mine and after about 5 hours driving with unit switched on, it was hotter than when it went in.
Is this a fridge or is it just a cool box that needs ice pack in it?
Post #432657 25th Mar 2017 11:03pm
bear100
It is a fridge, mine will definitely have a cold drink after 5 bours Mr. Green Sounds like you have an issue, do you get the green light on the switch? 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #432658 25th Mar 2017 11:06pm
AMTony
Yes, green light is on but only works when ignition is on.
Looks like back to dealer to sort?
Post #432665 26th Mar 2017 12:23am
Mine only works with the ignition on - but after a decent drive the drinks are cool
Post #432671 26th Mar 2017 7:05am
AMTony
In the handbook it says not to leave switched on as it can drain the battery.
This implies that it should work with ignition turned off?
Post #432676 26th Mar 2017 8:55am
Lutonboy
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
It's not a fridge in the true sense, it's a thermally insulated box with an attached heat sink and fan which is activated by the switch in the centre console. It's really a cool box, if the item goes in cold then it will maintain that coldness over a journey but it will not make things cold.
Post #432695 26th Mar 2017 11:47am
does having the AC on/off affect the box? ... - .- -.
Post #432696 26th Mar 2017 12:07pm
AMTony
Always keep a/c on.
The box managed to heat up the contents, the sides being quite hot.
Would have thought there should be some element of coldness, certainly not heat?
I think I may have an idea for LR......instead of something that cools and is of use on the odd hot day, why not have my system that can heat up your drink for the other 360 days of the year Rolling with laughter
Post #432714 26th Mar 2017 3:20pm
n1cktdv8
Stick a cold brew in it. After the next 5 hours it'll be ready to drink Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #432839 27th Mar 2017 11:09am
Paul J.
It uses a Peltier cooling device, so should cool the compartment down. If it is heating up, it is not out of the question that the power supply has been reversed! Shocked
Post #432848 27th Mar 2017 12:32pm
bear100
I am 90% sure mine has cooled down drinks and not just kept them cool Very Happy 2010 defender utility
1994 discovery 1
1975 bobtail (gone)
Post #432877 27th Mar 2017 4:04pm
mzplcg
Sounds like it's wired the wrong way. It uses a Peltier unit, much the same as heated/cooled seats do. Connect it up and it should get cold, but if the +ve and -ve are the wrong way it will heat up instead.
Post #432880 27th Mar 2017 5:11pm
