![]() | Home > Technical (L322) > ABS sensor ???? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I had a similar sensor error on the day of my mot which I put down to the wheels left hanging in the air or driving through a big puddle. I had HDC, EAS , ABS inactive on the dash and the car put its brakes on when I tried to pull away. I took off the ABS sensors and cleaned them , they are britpart, and just kept clearing the faults and eventually it stayed clear . It kept slamming the breaks on every time I reversed off my drive. The only other thing I did was tightening the transfer box main electrical connector. |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 ![]() ![]() ![]() |
Thanks for reply , I am in the process of replacing discs and pads so will have a look at sensors and replace the one that flagged the fault , I replaced one years ago in a td5 I had and remember I had to drive for a short distance to reset. Hopefully it will be just sensor . Range Rover ownership is an adventure !! |
Certainly an 'adventure' !
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Yes I've had this I thought I had been clamped! Its a wet weather thing and a guess which side sensor is causing it! |
the first thing I noticed is when i went through a big puddle and i got the bong of death and i think the first thing to come up was EAS inactive but nothing happened. it was only when i got home and parked up and then tried to move it i got everything light up and the brakes jammed on, i thought the wheel was coming off !! |
Seems like everything is a fight , had to grind heads off caliper carrier to hub bolts yesterday , happy days |
one of the things I have learned is that when i tried a torx bit, allen key or even a standard socket is to try the next size up , or down in the case of a socket and try tapping it in place as when the bolts get rusty they appear to be a different size, especially the torx type. |
Well , all caliper bolts had to be ground out. RHS caliper overhauled , disc and pads fitted , bled and wheel back on . Then onto the LHS abs sensor , drilled out with not to much effort only to find the problem is the reluctor ring is static in the hub. So new cv joint on order , removed the ball joint from hub whist hub in garage . Advice to anyone needing to remove outer cv joint " remove the complete driveshaft and stick it in a vice" |
What did you use to pop the inner CV joint out of the diff, just a pry bar ?
Yes , small pry bar , It came out no probs . I didn't see a retaining clip on the outer joint , I thought it was an internal snap ring . It's in bits in the garage so will have another look |
Actually i may be talking sh!te, i watched so many videos on how to remove the outer joint i think I am recalling one of those. I had a look back through my photos and found the attached. I did line up the joint so it was straight in line with the shaft and then tapped the inner race. I hammered and hammered and bent my special tool I had made trying to get it off but as soon as I put it in line and hit the inner race shown it just popped off.
No oil loss , the diff filler plug is at the same level as bottom of driveshaft |
Cool, that definitely sounds easier than trying to take of the outer CV joint with it attached to the car. |
