Home > Technical (L322) > L322 flat battery
Page 1 of 4 1234>
Realist
Wales
L322 flat battery
Anyone,
Wife started car, pulled out of garage, drove 100 yards and stopped. She parked up and went into a shop, came out and tried to start the car and all she had was a clicking nothing no turn over.
I was in work so managed to get to her and I checked battery voltage and that was 6.2v so I know the battery was flat but if that was the case how did she first start the car and drive 100 yards?
After a jump start the battery was taking 12.5v and with a rev of the throttle it went up to 13.6v I think so I presume the alternator is ok.
I have a feeling she left something on that drained the battery so called the AA out and had them just to check the battery, he said it was stuffed and only taking 7amps so I used my clamp meter and mine was showing 42amps so either its working fine or he was telling porkies, anyway he was their 2 minutes and drove off.
She has now gone to work (nights) and the car started fine but now I have one step stuck out and the other drivers side not working at all, any ideas?
Crazy day. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #432790 26th Mar 2017 10:25pm
Voltage shouldn't change when you rev it. I don't think.... There is nothing that can't be fixed with a hammer😜😜
Post #432792 26th Mar 2017 10:32pm
Realist
Wales
It was showing 12.6v on idle when revved it went up to 13.6v or there about so I know the alternator is charging.
If my brains are thinking right. Range Rover quotes.....
Post #432793 26th Mar 2017 10:37pm
Probably battery, possibly alternator.
Just enough juice to start it, but used up what was left in the 100 yd drive to the shops.
How long had the car been stood before use, and what trips prior to this, long, short etc?
Me, I would get the battery on charge for a good while, and see what happens, keep checking the voltage with engine off and engine on (at idle). With engine on you should expect 14v+ from the alternator.
Cheaper to replace a battery than an alternator, but you could then end up having to buy both! Big Cry .
Post #432803 26th Mar 2017 11:42pm
12.6v is a little low, would expect mid 13v with the engine running.
Suspecting diode pack on the alternator. At idle turn everything electrical on see what happens to the voltage. There is nothing that can't be fixed with a hammer😜😜
Post #432814 27th Mar 2017 7:36am
Realist
Wales
Yeh I'll turn everything on later and see if the voltage increases and go from their, but don't see why the steps stop working. Range Rover quotes.....
Post #432835 27th Mar 2017 10:56am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Was sitting in mine the ither day eith the iid tool plugged in and started playing with all the buttons.to see which one made the alternator work more. The front heated screen made the voltage jump by 0.6 , ( i presume to compensate for the draw on the battery ) by far the biggest jump of any toy in the car , maybe your wife put that on and it drained the battery ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #432878 27th Mar 2017 4:15pm
Realist
Wales
Well went to Halfrauds and they carried out a battery test and said the battery was fine and the AA guy said it was Censored .
Took the car for a log ride and so far all's ok I think it needs a good charge to be honest but time will tell. Range Rover quotes.....
Post #432882 27th Mar 2017 6:13pm
Rangeyman
There is a reset for the sidesteps if they are not working.Hold the sidestep button whilst torning on the ignition,hold for 15 seconds then turn off the ignition .
Post #432895 27th Mar 2017 7:43pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
AA man is financially motivated to sell batteries. Batteries to the AA is same as PPI to the banks.
Post #432901 27th Mar 2017 8:56pm
Realist
Wales
The AA Man said he didn't have the battery anyway and after 3 minutes drove off. Range Rover quotes.....
Post #432916 27th Mar 2017 11:38pm
Realist
Wales
Well I may of found my issue.
Went to put a charger on the battery and found the below!!!
Now gota try and find one today Sad Range Rover quotes.....
Post #432944 28th Mar 2017 12:22pm
Realist
Wales
Ummm cant see any reference to a 300 amp fuse anywhere in any manual, I'm wondering now if that's feeding some other axillary somewhere?
Post #432947 28th Mar 2017 12:54pm
Weegie
That looks a bit "after market" to me. Has it been used to replace YTA000040? John
GAP iiD BT-Sold
Post #432953 28th Mar 2017 1:46pm
Realist
Wales
Charged battery and again the cars battery went flat. When I jump start the car the voltage on the battery is 10.6v or there about's but when I turn on all window demisters it drops to 8 or so volts.
Therefore I presume the battery is not getting a charge but.......... I connected the below lead back to the battery terminal as a temp connection until I get a fuse and when I then test the voltage its sat at 11.5v or so and when revved its at 13.8 or so volts.
I'm now assuming that lead is coming from the alternator and its part of the charging circuit hence the reason the battery's going flat.
Fuse ordered.
Battery on charge.
Battery tester coming.
Now I hope my thinking is correct. Range Rover quotes.....
Post #432995 28th Mar 2017 6:57pm
Page 1 of 4 1234>
