Home > Technical (L322) > Help !!!
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Help !!!
Key in ignition but unable to turn , gear selector stuck in park .... ,
Heard a few "bongs" but couldn't see what they were as sun was on display
Unable to switch on to close windows sunroof and in a car park
Post #433226 30th Mar 2017 4:14pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
To close the windows try and press your remote for total closure. Can't help with the key problem though - sorry.... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #433227 30th Mar 2017 4:17pm
J evro
Thanks, absolutely nothing happening using remote, and have to leave the vehicle in 10 minutes for an appointment?
Post #433230 30th Mar 2017 4:21pm
have you been sitting there listening to the radio?
sounds like the battery has died and not enough power to disable the steering and gearbox interlock. There is nothing that can't be fixed with a hammer😜😜
Post #433231 30th Mar 2017 4:25pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
If you absolutely have to leave it as is and you have any tools then throw something over the ignition to hide the keys and disconnect the battery.
Sorry, I know this doesn't help actually solving the problem.
Post #433234 30th Mar 2017 4:35pm
UK Marine
Not sure about this but, key in the door lock and turn to lock then hold. That should shut everything up unless has been said the battery is flattish.... ______________________________
Simon
Post #433235 30th Mar 2017 4:43pm
J evro
Hmmm, I can take the key in and out no probs it just will not turn to position one even and as said cannot get hear selector out of park,
Think I remember the adaptive lighting icon flashing before it died on me ?
Post #433239 30th Mar 2017 5:26pm
J evro
I'm back with the car now ( no one stole it while I was away ),
I remember when parking it it really clunked into reverse and drive and doesn't usually would that be anything to do with it ?
Anyone got. Any more tries to get it going and get me home as would not want to leave it here after dark !
Post #433240 30th Mar 2017 5:33pm
CS
This sounds like when my battery was completely flat, the car shuts itself down and does not let you do anything. See if you can get charge into the battery via jump leads/booster pack (this may take some time) and you might need to short the system out to clear the blockage. Apparently once the battery gets low enough the car shuts off all function and that needs to be cleared before the car will start again. The recovery technician that helped me spoke to LR Assist even though I didn't have that cover any more and they advised him what to do, one would hope they would do the same for you if necessary, 0800 521 786.
Good luck! Only Range Rovers since 1988
Post #433242 30th Mar 2017 5:48pm
J evro
Ok thanks ( guess who left the XSPowerpack at home today after helping someone jump their car yesterday ?),
Had a New battery about a month ago,
Wierd how it would go flat whilst I'm driving it and set all the alarm icons off though don't you think ?
Post #433245 30th Mar 2017 6:01pm
J evro
How do you mean " may need to short the system to clear blockages"?
Post #433246 30th Mar 2017 6:04pm
think they mean a battery reset.
disconnect the battery ad touch the leads together. There is nothing that can't be fixed with a hammer😜😜
Post #433249 30th Mar 2017 6:18pm
mjdronfield
Can't you call the AA? Or join them and then call? Might get you moving. Other breakdown peeps are available, obviously....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #433252 30th Mar 2017 6:38pm
https://www.theaa.com/breakdown-cover/instant-cover
you can indeed
their number is
0800 887766 There is nothing that can't be fixed with a hammer😜😜
Post #433253 30th Mar 2017 6:40pm
J evro
Yep RAC just confirmed the Alternator is no more ( could smell it when he connected some power ) and prob my new battery as it read 0.23v😮,
So now got to wait and be recovered to an approved garage 20 miles from here then sort a lift out back home 20 miles the other way,
Ho hum only came here to see an Osteopath about my side/back as having some issues and now this ,
It's took my mind off the back pain though (thinking about the cost of new Alternator etc 😂),
Post #433258 30th Mar 2017 7:02pm
