Home > Maintenance & Mods (L322) > How to change bulbs in the roof courtesy lights
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Ok I'm stumped. Changing all interior bulbs to LED. But how the hell do you get to the one's in the roof courtesy light??
Tried following the user manual instructions but just feels and sounds like something is about to snap. It's like the plastic bezel is coming away but looks like a metal plate behind is staying firmly in place.
Pushed it back in for fear of damaging it, but now the centre courtesy light in the front unit doesn't work.... Mad 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #433683 3rd Apr 2017 3:56pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
If you pull out one of the black louver type vents behind the switches for turning on the map light you should be able to put your finger in and push out the unit that holds the bulbs and switches.
Post #433684 3rd Apr 2017 4:04pm
hamlet
Hope this helps.
Post #433685 3rd Apr 2017 4:08pm
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
You can't fit LED bulbs as there isn't enough room. What I did was buy some normal bulbs but ones with blue glass so they appear white when on.
If you remove the larger cover behind the light assembly (it just pops out) you can then reach in and press the 2 metal tabs in which releases the light unit.
Post #433697 3rd Apr 2017 5:05pm
hamlet
I have LED's fitted in all my internal lights, as do others I'm sure.
Post #433776 4th Apr 2017 12:47am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have all LED in the interior 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #433777 4th Apr 2017 1:17am
MattyB1983
Which type of bulbs are you chaps using.... ??
Post #433781 4th Apr 2017 7:03am
MattyB1983
I bought a few of this style which I used in the doors etc....
These don't fit... the hole is too small unless you maybe make the opening larger with a file...
Although thinking about it, this style might work...
But this style aren't very bright...
Post #433799 4th Apr 2017 12:06pm
most use these type, very cheap from ebay..
Post #433801 4th Apr 2017 12:18pm
MattyB1983
Can't see how you could use them..... ??? Not on the little roof lights anyway...
Post #433810 4th Apr 2017 1:32pm
The roof console is held on by 3 (maybe 2) screws in the sunglass holder. Removed these and the whole unit can drop down. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #433824 4th Apr 2017 4:36pm
dolph34
eBay Item No. 311698842066 ebay number for the kit i bought , i think they are the same as the ones in your picture. only bulbs that didnt work , were the wing mirror puddle lights which i sourced elsewhere 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #433837 4th Apr 2017 6:28pm
Rafterman
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
Lots of stuff on you tube re fitting LEDs on l322 The worst thing about being retired is you miss out on all the bank holidays
Post #433840 4th Apr 2017 6:38pm
SidewaysMatt
Cheers guys, popped the little square panel out from behind the light unit so could get my fingers in and release the light.
Having got the front unit out, I then knew where to stick my screwdriver to release the fittings for the rear one.
Fitted the LEDs no problem. The hole for the centre bulb in each unit was a smidge smaller than the map lights but the LEDs just fitted in Thumbs Up 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #434348 9th Apr 2017 4:01pm
p38arover
Australia
The owner's handbook instructions for removing the light panel is wrong. It tells to lever from the end. Don't!
Do as the workshop manual says and lever from the rear. Once you've popped it out, you'll see why. It is not designed to be removed from the side. Ditto the tailgate lights.
Nope, the hole is too small - I tried them today. I did get them to fit after modifying them but they aren't that bright. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #452016 25th Sep 2017 1:12pm
