![]() | Home > In Car Electronics (L322) > My Reverse Camera Install |
| Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67
Thanks.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
These are the people I got my camera from, worth having a word with.
Thanks. I've contacted them and await their reply......a tad frustrating that their cameras are up to 4 times as much as ones on Fleabay but if they work first time it's money well spent....
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
^^ Wot he said |
This is a reasonable camera, had it on my Shogun
| Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301
I took the plunge and got a wireless kit and camera. I hooked it up to a power supply to test it and was pleasantly surprised so I hooked it up to the car. I fixed the camera to the tow bracket next to the 13 pin socket and angled it towards the tow hook. I shoved the wireless unit up bahind the bumper for now and ran the wires under the tailgate and rigged a temp supply of the 12v socket.
I've now wired this to a 13pin plug and it's plug in to the tow socket and runs on a switched live so it's always on when driving if I want it and everything is outside the car.
The replacement camera arrived today and it works !!! So it's now installed in the same position as the incorrectly supplied PAL camera, in the bumper directly behind the towball.
That looks good, did you drill it into the trim on the bottom of the bumper? I looked at similar cameras but didn't want to have to cut into anything in case I messed it up. |
Yes. It comes with a drill mounted hole cutter but the hole needed enlarging very slightly. That part of the trim is actually double skinned and so was a bit fiddly to drill through. If it had been unsuccessful, I was going to fill the hole with a rubber grommet.
| ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94
Thought I'd add my experience to this post. I wanted a camera that would help line up the tow bar, and would also be of use when reversing up to walls etc.
I used the feed from the reversing lamps to power the camera, as I only wanted it on when going backwards |
| khyber Member Since: 21 Mar 2017 Location: new york Posts: 30
Is the power from reverse lamps enough to power the camera? I tested by connecting the camera power wire to the white yellow wire going into lower hatch and the earth to the brown wire but Eonon unit doesn't switch to camera when I select the reverse gear. The Eonon unit knows the reverse gear is selected because of the Canbus decoder and doesn't have to be triggered from the reverse lamps as far I know. |
| All times are GMT |
