![]() | Home > Technical (L322) > 4.2 S/C revs surging at tickover, running rough |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I have had similar on occasion. I had a slight misfire at idle yesterday morning from a cold start. Would suspect ignition coil on mine, it cleared within a few seconds of the car just idling and has not reappeared since.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I'm going to give a shot in the dark and say air leak, possibly a vacuum hose.
Wouldn't have thought an air leak would stop by turning the car on and off. Idle would probably be higher than normal as well all the time.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
MAFF |
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 ![]() ![]() ![]() |
So we had RAC out three times in last 36 hours. First 2 times it's thrown up air temp and air mass faults (MAF), so we got a replacement locally. It didn't help, and lit engine management light. RAC came out again, and faults code was Running lean bank 2, so it's being trucked 280 miles home. My suspicion now is injector.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Useless contribution! Sorry. |
No contribution is useless right now. Seriously considering sending the car back for a refund right now |
If it were the MAF, then disconnecting it and running it would tell you if the MAF was faulty if the car ran better.
Disconnecting the MAF just stalls the engine.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
My best guess is the car was running in "reduced performance" mode when your wife originally got home , and that's why it was idling badly .
