![]() | Home > Maintenance & Mods (L322) > 3.0 Td6 Vogue 2002 on 147000m pointers! |
| Muddydisco Member Since: 01 Apr 2017 Location: Tamworth Posts: 20
Just got my first full fat! Now apart from a full service, all oils and filters etc. What pointers should I be looking out for at that age vehicle? I have some service history, but not all.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
egr blank kit costs around £25-30 and you just fit it and thats it...
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Check the engine breather ASAP if its a loo roll type replace with the vortex type to save your Turbo. Make sure the engine gets up to temperature and stays there if not look at the EGR thermostat. I would leave the column alone once you have got it to the position you want, easy to take off the cowling and turn the threaded rods to adjust manually but take note it might have broken bits that have been modified to keep the column up and not in your lap.
| Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200
Unnecessary quote removed
I knew this motor was looked after as soon as I seen it! Was told a hgv mechanic had it, I am one too, egr already done |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
My 02 is on 136k and still goes like a train.
| All times are GMT |
