Home > In Car Electronics (L322) > Sat Nav
stu
Sat Nav
Just received a copy of the build sheet for my FFRR from JLR today.
it states: Euro Mapping DVD disc.
I thought all 2010-12 FFRR's had the stupid HDD system that only the stealer can update.
Any help on this would be appreciated.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434195 7th Apr 2017 6:44pm
Baltic Blue
Just checked build sheet for my 2011 VSE;
Navigation. Colour Nav System [025 EM ] if that helps? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #434201 7th Apr 2017 7:30pm
the dvd goes into the dealers computer and then the mapping is transferred via firewire to your hard drive.. ... - .- -.
Post #434203 7th Apr 2017 7:48pm
stu
Cheers Stan, that explains it.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434206 7th Apr 2017 8:25pm
stu
Just out of curiosity, where is the fire wire socket?
Has any one tried connecting and updating these themselves? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434208 7th Apr 2017 8:55pm
the socket is to the right of the glove box fuse box...i dont think anyone here has tried to access the hard drive..
but loading something alternative like igo primo would be nice.. ... - .- -.
Post #434211 7th Apr 2017 9:45pm
stu
Surely it's got to be possible to copy maps from a hard drive to the car via a fire wire set up.
Got to be something I need to look into. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434212 7th Apr 2017 9:57pm
i shall be watching this thread with interest Stu.. ... - .- -.
Post #434215 7th Apr 2017 10:15pm
Baltic Blue
You will have a line of FF's outside your house if you crack it !!!
Cheers Bow down G reg 2.5VM Vogue Portofino red 1991- 1999
Post #434245 8th Apr 2017 10:10am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
^ How very true.....
And many offers of gifts as well. Thumbs Up
Post #434256 8th Apr 2017 11:39am
stu
Just applying some logic, if the main dealers up load maps from. DVD to the system via the fire wire socket, surely copying maps to a hard drive and doing it via a fire wire cable will have the same effect?
Not top of my list at the moment, but I will look into it.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434300 8th Apr 2017 10:25pm
Giantlandyman
The main dealer download the map to the hard drive and then upload to the car, I believe.
I only say this because when I had mine updated, the connection was lost so the download had to be re-started so the 45mins to 1hr morphed into almost two hours.
I would love for it to be as simple as putting a disc on a hard drive and then uploading but I wouldn't mind betting there is some security code or authorisation number somewhere.......really hope I am wrong though.
Post #434302 8th Apr 2017 10:48pm
GGDR
Doesn't the head unit take input from individual boxes? like the TV module.
So is there a Nav unit between the head unit and the firewire HDD maybe? Wouldn't it be great if, like Stan mentioned, a newer system e.g. igo primo could be fed into he head unit?
I think a lot of other LR vehicles have the same HDD system. So in addition to a queue of us forum members, there will be a huge wider LR customer base for whoever cracks this.
Who was that guy that offered audio/amp upgrades? Maybe we talk to him?
. Cheers, Greg
Post #434315 9th Apr 2017 7:55am
stu
it just amazes me that 10 years ago, when I strayed to the dark side for a change (please forgive me.. Bow down Bow down Bow down )
I bought a VW Touareg with a fantastic head unit with a 30gb hard drive fitted. It stored all the maps, more music than you could shake a stick at and even pictures!
I upgraded both firmware and maps several times just by inserting a DVD.
JLR, if you are listening your system makes no sense either than to make money!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434323 9th Apr 2017 9:39am
Baltic Blue
Does the sat nav updating PDF in the Workshop Manual help you ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #434346 9th Apr 2017 3:10pm
