Home > Maintenance & Mods (L322) > air suspension fault
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
hi all, can anyone help, my L322 was parked for a couple of days on a slope when i went to use it the message "air suspension inactive flagged up, i also have a abs light on the dash, the front air spring are quite low but the rear ones are high, the raise/lower switch isnt iluminated. any ideas
Post #434261 8th Apr 2017 12:37pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have you carried out a battery disconnect yet? The proper procedure is in the wiki section above..
When you reconnect the battery make sure that you turn the steering wheel all the right and hold for a second then all the way left and hold for a second..
Does it flag any other messages when you move the car e.g. HDC fault
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #434268 8th Apr 2017 2:20pm
razzer
no other messages, i did try disconnecting the battery to no avail.
Post #434272 8th Apr 2017 2:33pm
UK Marine
Do you have diagnostics available?
Most on here would recommend the IIDtool from GAP. It's likely that you have a hard fault if you've got no lights on the suspension panel and can only be reset using diagnostics.
If you say that the front is lower than the rear then you may have a leak in one of your air springs. Best to get the codes read first before looking at the wiring.........
Simon
Post #434275 8th Apr 2017 3:32pm
razzer
thanks for your input
Post #434277 8th Apr 2017 4:53pm
